Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > International Forums > Canadian
Old 06-09-2008, 04:58 PM   #1 (permalink)
Member Number: 38082
Default help pls!!
ok so the other day i was driving down mavis when i came to a stop at a light. Light turns green and i go, as im driving i hit one of those stupid bumps on the road that you just cant avoid and all of a sudden the cluster and everything turns off and on twice and stays on. so i keep on driving, and now all of a sudden everytime i swich grears at low rpms the car studders for some reason and i keep hearing the wga going off everytime it studders. theres no back fire so i know it cant be the sparkplugs. oh and not to mention the engine light came on and then turned off like 20 min later. i just got the motor rebuilt about a year and a half so the one year warrenty is gone and the dealership has fucked me up the ass too manny times now. what do you guys think. i really need the help.
chico120 is offline   Reply With Quote
Old 06-09-2008, 05:22 PM   #2 (permalink)
canadian_made_srt-4's Avatar
Member Number: 22368
Trader Rating: (29)
did your car bottom out sounds like you might have cracked the hot side charge pipe.
as for the cluster I have no idea and the check engine light could be that the bump triggered your knock sensor?.....
543WHP HIGHEST WHP PUMP GAS SRT-4 IN CANADA
canadian_made_srt-4 is offline   Reply With Quote
Old 06-09-2008, 05:53 PM   #3 (permalink)
hmm ill have to look at that tomorrow but i doubt thats what it is because it wasnt that hard of a bump. another thing i hear is the sound of spooling becomes higher pitched at low rpms for some reason.
Old 06-09-2008, 06:19 PM   #4 (permalink)
GLH
GLH's Avatar
Member Number: 13115
Trader Rating: (34)
LOL you must have a CAI it is hitting your positive battery cable
86 GLHS 315
05 SRT4 GT-A #166
2008 Mobile 1 GT Sprints
2007 Canadian Touring car Championship
sponsored by Fast Trac /ftrac.org
GLH is offline   Reply With Quote
Old 06-09-2008, 08:08 PM   #5 (permalink)
Trader Rating: (29)
very true although most CAI's are not chassis grounded seeing as they use rubber couplers.. and they run beside the battery not ontop once the hood goes down there wouldnt be enough clearence for the CAI to touch the top of the battery...now maybe the battery hold down broke and the battery is hitting the hood?.......But that doesnt explain the louder then normal spooling either......
take a close look under the hood when you get a chance I'm sure you will find the issue....
Old 06-09-2008, 09:23 PM   #6 (permalink)
SRToc Member
blksrt404's Avatar
Member Number: 4798
Trader Rating: (29)
Have you tried resetting the PCM?
Fastest SRT4 in Canada for 2007 @ 128.77
Quickest SRT4 in Canada for 2007 @ 11.286
Trying to be one of the first Canadians into the 10's
blksrt404 is offline   Reply With Quote
Old 06-10-2008, 10:56 AM   #7 (permalink)
i do have a cai and i did just install a new battery not too long ago but why is it making a wierd noise at spool
Old 06-10-2008, 01:55 PM   #8 (permalink)
2PorkChop4U's Avatar
Member Number: 9129
Trader Rating: (21)
TPS Sensor (may need the Update or Fix)? Bad Coil Pack? sounds igniton related....
2004 Dodge SRT-4 "1MEANSRT"... Mopar Stage 3 W. Turbo Toys, AEM CAI, Mopar Exhaust, MSD Wires, Mopar STS, DEI Cry02 Intercooler Sprayer Kit, DCR Oil Modifier, DCR 55mm Ported TB, MaxxFabb 3" o2 Stg 3 Housing, 3" U-R Downpipe w. High-Flow Cat, AGP Dogbone MM&TM, Energy Suspension Prothane LCA's.
2PorkChop4U is offline   Reply With Quote
Old 06-10-2008, 10:47 PM   #9 (permalink)
SRToc Member
blksrt404's Avatar
Member Number: 4798
Trader Rating: (29)
Boost Leak??? Maybe you knocked a clamp loose...Did you check both intake and exh. inlet/outlet on the turbo???
Old 06-11-2008, 08:25 AM   #10 (permalink)
Member Number: 36651
Trader Rating: (34)
The first part of your message on the turn off/on issue definitely sounds like the CAI hit the positive part of your battery and/or cable. Last year, after we all thought my car blew up, we pulled it all a part and put it back again. Then every time I accelerated the car would turn off and back on again, beeping at me, etc. We finally figured out that the CAI was hitting the positive cable and shorting out the car. Stuck a rag between the positive cable and CAI, until a more permanent solution was found.
The other things you've noticed as a result, could be a result of the short and somethings being reset because of the short. I'd try what blksrt404 suggest and reset the PCM and check for possible boost leak and see if that helps.
2003 GT PT Cruiser
PTP SSTv2, PTP ported manifold, PTP 650 injectors, PTP 55mm PT TB, Needswings DP w/e-cutout, Stage 1 PCM, PSI-FI powerpaq, Amx1397TTAB, AGP UCP, Good Hood w/CAI, DCR Oil Modifier, Turbo XS HPBC, and S2 WGA.
Street tuned April 29/07 at 18psi, thanks to Aaronneon@Realtune.
Dyno tuned Oct 28/07 at 20psi (278HP & 328tq), thanks to Scarboroughdub.
love2race is offline   Reply With Quote
Page generated in 0.27466 seconds with 11 queries
