Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Regional Forums > International Forums > Canadian
Old 09-19-2006, 11:31 AM   #1 (permalink)
MoparEd's Avatar
Member Number: 32816
Trader Rating: (39)
Default Boost Leak from BOV
hey,
I have yanked my mopar bov apart 3 or 4 times trying to fix a boost leak, but Im not having any luck. My car with the key turned to the on position and airbox lines plugged will only let me get the boost up to 5 psi on my gauge. I noticed that the surge valve when tightened down is not completely flat on the blue plate. I thought I might have a bent surge valve , so I used another one and its the same. I notice the same results with the key in both on and off positions. This is my first attempt at doing a boost leak test , so I wouldnt be surprised if im doing something wrong. Im using the stock airbox elbow with a 2 inch pvc cap with a valve in in, Im also using a compressor that can put the volume of air in the system ( i have it set at 22 so I dont put too much air in there) I did searches on the forums and the only thing I could come up with is use liquid engine gasket sealer, but I wanted to check with you guys first to see if any of you had run into this problem. any suggestions will be great
thanks
Ed
Canadians, Need some Powdercoating?
Click Here to See some of My powdercoating
PM me for Quote.
MoparEd is offline   Reply With Quote
Old 09-19-2006, 04:43 PM   #2 (permalink)
c2k
c2k's Avatar
Member Number: 2639
Trader Rating: (63)
I used the make your own gasket w/ the adesive that comes w/ it and a small amount of cooper rtv gasket. I've had good results with it before i sold it to jay.
http://www.ontariosrtclub.com <----- alternate site for canadians and ontarioians locally.
SCT Tuned by Kevin@AGP Turbo
Quote: Originally Posted by DODGETWEAKER
Boost is like crack and I am your dealer. Come here lil' junkie and take your medicine.
Dodgetweaker is a part of the SRT Engineering team
c2k is offline   Reply With Quote
Old 09-19-2006, 05:25 PM   #3 (permalink)
ac_srt4's Avatar
Member Number: 32920
Trader Rating: (48)
my old mopar bov doesn't leak from the gasket. it leaks from the egg-shaped hole where it suppose to blow air out.
i spray soap on it and it's making bubbles from the holes!!! and i replace with hks right away.
MODS:
NOS Octane Booster
Stickers, those 5+ hp ones, lots of them!!!!
RAPOM +33% long throw shifter
K&N steam air intake system, complete
ac_srt4 is offline   Reply With Quote
Old 09-19-2006, 05:37 PM   #4 (permalink)
SRT4Jay's Avatar
Member Number: 34096
whichever gasket that canuck_2k made with the BOV i bought from him works great, no leaks from mine, as far as i know... i also have the ptp spring...but then as i remember you do to right ed?
Quote: Originally Posted by smoger View Post
"Bravo team this is charlie requesting clearance to land the ROFLCOPTER"
SRT4Jay is offline   Reply With Quote
Old 09-19-2006, 05:53 PM   #5 (permalink)
Member Number: 14212
i just used gasket sealer one the edges and also i siliconed my gasket down so it doesn't move out of place when installing the bov.
i havent had any leaks .
Frosty is offline   Reply With Quote
Old 09-20-2006, 11:51 AM   #6 (permalink)
MoparEd's Avatar
Trader Rating: (39)
thanks guys,
I'll be doing the homemade gaskey with copper rtv next week.
cheers
Ed
Page generated in 0.21881 seconds with 13 queries
