Thanks to everyone for all the nominations!
My 2004 SRT-4 - It's "Mostly" stock...
Powertrain:
Forced Performance "Green" turbo
CNC Port Race Head (+1,+2)
STOCK Bottom-End
Mopar "Stage 2" PCM
DeatschWerks 750cc Injectors
MaxxFab custom 3.5" O2 housing
MaxxFab SEE with High-Flo (Metal Core) Cat and Magnaflow Resonator
DCR Crane 16's
DCR 5 Layer HG
DCR Coated Oil Gears
DCR Oil Modifier
DCR Lash Adjusters
DCR Head Nuts & Washers
APR Head Studs
Unorthodox Cam Gears
Stage 3 fuel system w/
TKMotorsports Walbro 255
Mopar Toys w/ double sprayers
SPEC Stage 3 clutch
Rage-Tek Ported Intake Manifold
60MM Iceman TB
AGP Stage 3 WG
Greddy Type-S BOV
AIS Intercooler
Samco Hoses
Iceman intake
Booger Bushings
Custom mounted Mopar STS
AGP Road Race Motor/Tranny Mounts
Suspension:
Custom Koni 8611 Race Inserts in SRT strut bodies
Ground Control Camber/Caster Plates
Eibach Coilover Springs 650F/850R
TCE/Wilwood 13x1.1 BBK
Custom CNC hubs at all 4 corners (5x114.3)
to accomodate -
18x9.5" 15mm Enkei RPF1's in SBC (or silver depending on my needs)
285/30/18 Continental Extreme DW tires (Redline T/A & DD'ing)
275/35/18 Hankook Z-214 (C-91's) (NASA & Misc Ass kicking)
Custom Timken Wheel Bearings and Seals
ARP Wheel studs
Rage-Tek LCA Bushings
Hotchkis Sways (F&R)
DC Strut Tower Bars
PWerks Crossmember Brace
High Durometer Urethane bushings thru-out
Aerodynamics/Exterior:
APR Front Splitter
APR GTC-200 Wing (custom mount points)
RFR Rear Diffuser
(Custom Front Fascia, Splitter, Undertray under development)
Custom Brake ducting to BBK
Custom Fiberglass Sunroof replacement
Custom modified Fenders and Rear Quarter PanelsCarbon Fiber Trunk
IPP CF Hood
Safety/Interior:
RaceTech WHR-4009 race seat
Simpson Cam Lock Harnesses
RaceCarBuilders Custom 6-Point Roll Cage - FULL interior utilization possible
Sparco Alcanterra Steering Wheel
Triple Autometer Gauges (Oil Temp/Press/30-30 Boost)
AEM Wide Band
Panavise "Traqmate" mount
Relocated (to trunk) Optima Red Top
Custom battery cut-off
Gutted Interior
All sound deadening removed
All seats removed
Dash is 95% complete (no air bags) and A/C is still functional
Stuff just for looks:
ABSOLUTLEY NOTHING ! ! !
Let's not forget this.....
