Old 11-01-2009, 10:18 PM   #1 (permalink)
silver03srt's Avatar
Member Number: 54252
Default whats goin on with this...
ok. having a problem with my car... it has to be with the tune. only other conclusion is the tps isnt getting read by the computer.. but whenever i shift over 6k or hit the rev limiter the car just cuts out.. i have it floored and it does nothing.. doesnt matter if i wot shift or if i granny shift it. lmk what u guys think.. i swear its something with the tune.
Quote: Originally Posted by thatguy27 View Post
. Take it to a shop or your pistons might see jesus.
silver03srt is offline   Reply With Quote
Old 11-01-2009, 10:42 PM   #2 (permalink)
Chief's Avatar
Member Number: 61336
do you have the tps fix? connecter and better wires? My tps is mess up currently, idle sticks, and have same issues shifting and fallin on its face. Pretty sure alot has to do with tps, because 2 days ago it was fine. now all of a sudden its shitty, PLay with wires and sometimes ti works, sometimes it dont. our tps wires are garbage.
Built bottom end
strapped BC and CP
HTA 60
PTP when you fedex man gettin this block?
Chief is offline   Reply With Quote
Old 11-02-2009, 07:20 AM   #3 (permalink)
yah i did the tps fix a while ago.. i think it might be the actual tps sensor. im gonna test it today at work. cause it had been sitting for a few months while the car was blown up.
Old 11-02-2009, 08:48 AM   #4 (permalink)
duster360's Avatar
Member Number: 45182
You need to datalog instead of guessing.
Old 11-02-2009, 10:40 AM   #5 (permalink)
ptperformance's Avatar
Member Number: 25514
Trader Rating: (567)
A data log with some additional items like AFR's and a more clear detail as to what happens. We have seen this happen in the past and it has something to do with COT. A shorted sensor wire will screw with the tune also, we have seen this on 3 occations now where the TPS or O2 signal wires have been shorted or cut and the tune is all crazy when the customer loads it. Get me a data log sent over and we will take a peak at it, thanks.
Home of the DSP Tuned 657 WHP SRT4 Neon, 593 WHP SRT4 Caliber and the fastest stock turbo DSP tuned SRT4
DSP or Trinity
Old 11-02-2009, 08:57 PM   #6 (permalink)
cano's Avatar
Member Number: 2373
I had exactly that symtom a while back. Mindmelt fixed Torque Management and never happened again.
12.706 @110 6/20.09 -- 12.827 @ 108.66 2/10/08
Stage 1, d44, DSP, 3" HP Racing turboback, Filled Motor Mounts, Spearco FMIC, Fuel Return Kit. M/T DR's on Rota Slipstreams
cano is offline   Reply With Quote
Old 11-03-2009, 12:24 AM   #7 (permalink)
Chief's Avatar
sounds like cot, you need to get a rescale and have them take that off. same problem hopin rescale helps
Old 11-03-2009, 06:17 AM   #8 (permalink)
cot? sorry. kinda new to the tuning world.
Old 11-03-2009, 07:48 AM   #9 (permalink)
Gizmodo's Avatar
Member Number: 22931
COT = Cat Over Temperature. It is a "feature" of the PCM that causes it to dump fuel into the engine when it determines the EGTs may damage the cat.
Gizmodo is offline   Reply With Quote
Old 11-03-2009, 05:19 PM   #10 (permalink)
DSport Workgroup Mod
Member Number: 66961
You guys should pay attention to what Cano said....
Mindmelt101 is offline   Reply With Quote
Page generated in 0.14036 seconds with 13 queries
