Old 11-07-2009, 02:58 PM   #1 (permalink)
Brian87gt's Avatar
Member Number: 4097
Default What will a 3BAR sensor read on the Diablo
Was doing a datalog and was wondering what the 3 bar will read in the log? I am getting 15. Thanks
Brian87gt is offline   Reply With Quote
Old 11-07-2009, 03:11 PM   #2 (permalink)
bene's Avatar
Member Number: 53801
Trader Rating: (40)
what?
it will read whatevers at the manifold...
bene is offline   Reply With Quote
Old 11-07-2009, 03:16 PM   #3 (permalink)
Brian87gt's Avatar
Member Number: 4097
Mine was reading 15.00 with the key off, wanted to see if that was correct. Thanks
Old 11-07-2009, 05:05 PM   #4 (permalink)
bene's Avatar
Trader Rating: (40)
should be around 0.0 key off, -14.5 idle
Old 11-07-2009, 06:32 PM   #5 (permalink)
turbo666's Avatar
Member Number: 25206
Trader Rating: (31)
No, your baro is 15 with key off and the manifold pressure reads atmospheric pressure with the key on engine off. I have had mine ready up to 43.45psi. That's absolute boost pressure, which adds atmospheric to the actual manifold pressure. I would say the sensors peg out around 29ish psi.
Nigel
04 Srt-4-AGP Borg Warner S360-RS, E85, and MUCH MORE coming soon...
7.493@99.56<-- granny shifting on 30r with 93/meth <--OLD SETUP!
FIRST TO MAKE BIG TURBO PCM BOOST CONTROL WORK ON DIABLO!
For custom tuning, installs, and transmission rebuilds PM me!
www.trudynosports.com
Old 11-07-2009, 09:56 PM   #6 (permalink)
Brian87gt's Avatar
Member Number: 4097
Thanks
Old 11-07-2009, 10:10 PM   #7 (permalink)
Member Number: 53360
What would cause the dataviewer not to read over 18psi even if you have 3bar sensors that work correct and everything is scaled correctly? Nigel can varify this.
2004 SRT-4 Murdered, Built, Cammed, GT35R, Meth, N2O
2003 Dakota R/T Charcoal, Stock
mjennings2 is offline   Reply With Quote
Old 11-09-2009, 08:23 AM   #8 (permalink)
ptperformance's Avatar
Member Number: 25514
Trader Rating: (567)
First off, how much boost are you running? Next are you sure your reading the correct PID? Last I would check the rescale, just to verify that it was done properly.
Home of the DSP Tuned 657 WHP SRT4 Neon, 593 WHP SRT4 Caliber and the fastest stock turbo DSP tuned SRT4
DSP or Trinity
Old 11-09-2009, 05:42 PM   #9 (permalink)
26psi. Im doing avg map to use - baro, always 18.36 - 18.62 when I run 20-26psi. Had it double checked.
Old 11-09-2009, 08:00 PM   #10 (permalink)
duster360's Avatar
Member Number: 45182
18.36-18.62 is exactly what the Stock sensors and a Stock map scale would read.
You either have 3bar sensors with a stock map scale or Stock sensors with a 3bar map scale.
Check your Baro at Key ON Engine OFF and compare it to MAP. It should be off by quite a bit.
Old 11-10-2009, 05:47 AM   #11 (permalink)
turbo666's Avatar
Trader Rating: (31)
Mike, I'm looking at the last log you sent me and your Baro is reading 14.3-14.4. That's perfectly fine. I told him to try a locals 3 bars to see if that changes what we see.
Old 11-10-2009, 06:52 AM   #12 (permalink)
Yea Im gonna try that once I get someones that I know works.
Page generated in 0.15272 seconds with 13 queries
