Old 12-17-2008, 06:58 AM   #1 (permalink)
dongalonga's Avatar
Member Number: 59682
Default What Parameters to Datalog
Like the title says which ones should I be logging.
dongalonga is offline   Reply With Quote
Old 12-17-2008, 07:13 AM   #2 (permalink)
DSport Workgroup Mod
Member Number: 66961
Here is my Development dash... You'll notice that it has a ton of stuff but you can take off whatever you like... I also have another that is for trims etc...
File Type: zip SRT_DASH_DEV.zip (441 Bytes, 739 views)
Mindmelt101 is offline   Reply With Quote
Old 12-17-2008, 08:42 AM   #3 (permalink)
duster360's Avatar
Member Number: 45182
Rev C
20AUG09: add Ambient temp, TM, TIP, EGT and Wg; Removed Baro, PRatio, IPW
19APR10: Removed EGT, Spark Adjust,TURBO WG ADAPT DELTA; Added TURBO TOTAL AF DES FILTD
Dataviewer Dashboard place in MyDocuments/dataviewer/dashboards
Everyday tuning Spark and Fuel ,LOG THESE AT A MINIMUM
Ambient Temperature-->
AMB TEMP--Outside Air temp
Knock control-->
KnK ST Retard--show amount of timing retarded for PCM's instant response to Knock
KNK LT Retard--show amount of timing retarded for PCM's long term or learned response to Knock. If the PCM sees a consitant amount of ST KR, it will use LT KR to try to keep ST at 0.
Spark-->
Actual Spark Cy1( you can do Cyl 2,3,4 also but there's USUALLY little difference)--Final timing advance after all modifiers.
EPDSS-->
RPM
Foundation inputs-->
MPH--Car's speed
Throttle Sensor Input-->
*More clearly IDs WOT
THR POSN---Throttle position sensor voltage-~3.6-3.9v = WOT
Map-->
AV MAP TO USE--Absolute pressure inside your intake manifold(Boost = MAP - BARO)
AV TIP TO USE--use min TIP psi as "Baro"
FUEL FLOWS--->
1/1 LONG TERM ADAP--How much your PCM is adjusting the fuel table--Usually under 15% is fine,,Over 20% is baorderline, more than 25% is not fine
1/1 SHORT TEM ADAP--Show instantaneous Upstream O2 sensor adjustment to fuel table
BARO--FOR HANDHELD GUYS ONLY Barometric pressure--Needed for boost calc(Boost = MAP - BARO)
COOLANT TEMP-->
ECT--Engine Coolant Temperature
CHARGE TEMP-->
ACT--Air Charge Temperature--Measured by ACT sensor in cold pipe right before throttle body
DESIRED FUEL AIR-->
OPEN LOOP FA--Commanded A/F that the PCM is trying to reach. 93tune=11.77:1. THIS IS NOT YOUR TRUE A/F!! You need a widband to measure your actual A/F. OLFA is usually anywhere from .2 to 3 points or more different from TRUE A/F.
Torque Mangment-->
TRQ DESIRED--Final Desired Torque the PCM is trying to reach after ALL modifiers applied
TURBO TOTAL TRQ DESIRED = Desired Torque table value (TURBO TRQ POTENTIAL STP) minus most, but not all of the PCM's Torque limits on ECT/Gear/MPH/RPM ect.
Wastgate Control-->
TURBO WG DC--Final WG soleniod duty cycle
TURBO TRQ POTENTIAL STP--Desired Torque value from DT table BEFORE and modifiers. Changing "Boost" on your DSP will change this value
TURBO TOTAL AF DES FILTD--Airflow calculation used to determine what row of the WG DC table to use
The more BS you log the SLOWER the sample rate is. So if you're doing some serious tuning/diagnostics, don't log SHIT YOU DON'T NEED, it will just slow things down. With that said, I have logged over 95 pids at once and the slowest rate I have gotten was 1.2 seconds/sample.
TDS is the best choice for ALL your CMR Tuning.
Old 12-17-2008, 10:15 AM   #4 (permalink)
Yeah what ^^^ he said. lol.
Old 12-17-2008, 12:38 PM   #5 (permalink)
dongalonga's Avatar
Wow thanks this is going to make my life that much easier. Mindmelt101 I emailed that info like you told me as well.
Old 12-17-2008, 03:21 PM   #6 (permalink)
01StratRT's Avatar
Member Number: 3294
Thumbs up
Awesome! Good job guys
Mods:
ED Super Beast IC
PTP Check Valve
Mopar STS
Gerry's Custom door sills & shift knob
Realtune 60mm TB
JMB SRI & CC
AGP Trans & Motor mounts
DCR Oil modifier
01StratRT is offline   Reply With Quote
Old 12-18-2008, 05:05 PM   #7 (permalink)
starman's Avatar
Member Number: 20348
Quote: Originally Posted by duster360 View Post
INJECTOR--->
AVG TOTAL WORKING PW
I can't find that parameter on the handheld
starman is offline   Reply With Quote
Old 12-19-2008, 06:38 AM   #8 (permalink)
duster360's Avatar
80% of all parameters(there's close to 200) are NOT in the handheld. PC required
Old 12-19-2008, 07:38 AM   #9 (permalink)
dongalonga's Avatar
Can't wait to hear from Brian. Then I can hit the dyno and do some tuning.
Old 12-19-2008, 10:40 AM   #10 (permalink)
starman's Avatar
Thanks, i will try it with my laptop
Old 12-21-2008, 05:43 PM   #11 (permalink)
KrazyRdR83's Avatar
Member Number: 55270
quick question...maybe i keep passing it, but where do you go to adjust the tire size through the DS?
so if we wanted to watch more parameters a laptop would be best?
04 Neon SRT-4 - lifetime project
99 R1 - DD
08 Kia Optima - comfort mobile
STUFF FOR SALE:
http://www.srtforums.com/forums/f256...e-look-569419/
KrazyRdR83 is offline   Reply With Quote
Old 12-22-2008, 12:07 PM   #12 (permalink)
letxen3's Avatar
Member Number: 41680
last time i check with brain on this that feature is not available to us. why what size wheel and tires are on your car now I can check if the speedo is off.
James | 2004 PT Cruiser 5spd
AEM | Aeroforce | AMX | AutoMeter | DiabloSport | Dynamic Turbo | HKS | K&N | Kobe | Mopar | MSD | Needswings | Nexen | NGK | Perrin | PTPerformance | Rage-Tek | Spec | Zeitronix
letxen3 is offline   Reply With Quote
Old 12-22-2008, 01:20 PM   #13 (permalink)
KrazyRdR83's Avatar
ahhh that would explain, i'm on the stock rims right now, with 225/45 tires
99 R1 - DD
STUFF FOR SALE:
Old 12-22-2008, 01:26 PM   #14 (permalink)
letxen3's Avatar
your fine the speedo is not off.
Tire size calculator
Old 12-23-2008, 09:15 AM   #15 (permalink)
dongalonga's Avatar
Wow the first thread I got stickied sweeeet
