Old 04-12-2009, 08:34 PM   #1 (permalink)
Pomz23's Avatar
Member Number: 64878
Trader Rating: (19)
Question Wanting DSP, but what about logging A/R?
Im sure there are threads about this, but you try searching for a/r on this site. Is there any future plans for diable logging a/r. Or is there a solution already out.
Metal Werkz - For Sale: New Custom Aluminum Door Sills and Radiator Shrouds!!!!!! Click here for my site.
Pomz23 is offline   Reply With Quote
Old 04-12-2009, 08:44 PM   #2 (permalink)
canadian_made_srt-4's Avatar
Member Number: 22368
Trader Rating: (33)
you mean A/F right? the srt uses a narrow band o2 system I believe you will still need a wide band to use to dial in the tune.
I see Turbo666 is in here so I'm sure he will give you a better answer shortly.
543WHP HIGHEST WHP PUMP GAS SRT-4 IN CANADA Parts for sale http://www.srtforums.com/forums/f293...6/#post7038270
canadian_made_srt-4 is offline   Reply With Quote
Old 04-12-2009, 08:45 PM   #3 (permalink)
turbo666's Avatar
Member Number: 25206
Trader Rating: (31)
If your wideband has a analog output wire then you can connect to the trinity and log afr's.
Nigel
04 Srt-4-AGP Borg Warner S360-RS, E85, and MUCH MORE coming soon...
7.493@99.56<-- granny shifting on 30r with 93/meth <--OLD SETUP!
FIRST TO MAKE BIG TURBO PCM BOOST CONTROL WORK ON DIABLO!
For custom tuning, installs, and transmission rebuilds PM me!
www.trudynosports.com
Old 04-12-2009, 10:06 PM   #4 (permalink)
Pomz23's Avatar
Trader Rating: (19)
WOW yeah, my bad.
Old 04-12-2009, 10:07 PM   #5 (permalink)
Pomz23's Avatar
Trader Rating: (19)
Dont have either a DSP or a wide band yet. the trinity was like ~700$ last time i checked so that's out of the question.
Old 04-12-2009, 10:12 PM   #6 (permalink)
turbo666's Avatar
Trader Rating: (31)
Well, as of now, that is your only.
Old 04-12-2009, 10:12 PM   #7 (permalink)
csmsach's Avatar
Member Number: 33253
Once I get the kinks worked out, I will share how to log A/F with the dsp, until then there is no economical way to do it using diablo tools.
csmsach is offline   Reply With Quote
Old 04-12-2009, 10:12 PM   #8 (permalink)
Member Number: 64760
Trader Rating: (20)
wideband + aeroforce gauge
i plan to datalog all the essentials on the DSP, then the above for my AFR's once my tune gets ironed out w/ aaron.
91PumpKing. is offline   Reply With Quote
Old 04-13-2009, 06:53 AM   #9 (permalink)
holmes14's Avatar
Member Number: 64416
hmm areoforce datalogs the wideband? I know there are people working on getting the dsp to log the eugo wideband gauge so i left my com wire in place with a prayer someone figures it out. Wheres NUTZ he can help explain maybe.
holmes14 is offline   Reply With Quote
Old 04-13-2009, 07:49 AM   #10 (permalink)
Pomz23's Avatar
Trader Rating: (19)
Question
than can someone please justify spending 400$ on something can only do a half assed tune. Im no tuner, but it just is not making sense to me to spend so much time tuning if I cant log A/F to know what really happening. I guess I could log with a scan gauge but it would require alot of looking back and forth between scan gauge and laptop and trying to match things up. Possible but annoying.
I cant believe noone has found a flawless way to use the aux input on DSP to link it to a wideband. From what I read, the DSP can read voltage output from any source. Noone has an update for entering a voltage to A/F conversion equation into the DSP???
Old 04-13-2009, 08:21 AM   #11 (permalink)
csmsach's Avatar
It can be done.....YouTube - Diablo Sport Predator Logging AEM 0-5v Output on an SRT4
When I get the calibrations completed I will release to the public how to do it.
I am pretty sure that Diablo purposely left off an analog input only to create another product that included it later down the road. The dsp gets your mouth wet but leaves you thirsty for more....But your gonna pay for it and it definitely is not worth the price...
Old 04-13-2009, 10:22 AM   #12 (permalink)
Trader Rating: (20)
WOW.... nice man.
Old 04-16-2009, 02:22 PM   #13 (permalink)
smokin-ricers's Avatar
Member Number: 10183
I am RUNNING WITH 2 DEVILS DIABLOSPORT AND DEVILSOWN WATCH OUT
I am way to cheap and way to smart to buy a trinity.....
smokin-ricers is offline   Reply With Quote
Old 04-21-2009, 03:50 AM   #14 (permalink)
csmsach's Avatar
Got the prototype input device finished tonight, here is my log output from my dsp with Actual AFR being read from my AEM Wideband, other values should be self explanatory. Log only includes data from when I was at WOT. I am also logging around 29 PID's which explains the sample rate, I only included a fraction of the logged data....
Code:
| time        | rpm    | Boost | Desired Torque | Desired AFR | Actual AFR |
| 0:00:02:618 | 3064.0 |  1.69 | 173.3          | 14.37       |     14.706 |
| 0:00:02:857 | 3066.0 |  5.31 | 217.1          | 11.77       |     14.118 |
| 0:00:03:092 | 3158.0 | 11.29 | 269.8          | 11.63       |     14.118 |
| 0:00:03:332 | 3247.0 | 14.16 | 295.2          | 10.92       |     12.236 |
| 0:00:03:567 | 3329.0 | 14.48 | 302.1          | 10.77       |    11.7648 |
| 0:00:03:804 | 3415.0 | 15.14 | 322.8          | 10.65       |    11.7254 |
| 0:00:04:044 | 3522.0 | 15.12 | 324.7          | 10.58       |    11.7254 |
| 0:00:04:278 | 3606.0 | 15.03 | 327.5          | 10.60       |    11.7254 |
| 0:00:04:523 | 3687.0 | 14.83 | 324.5          | 10.65       |    11.6862 |
| 0:00:04:761 | 3789.0 | 14.59 | 324.4          | 10.69       |    11.7254 |
| 0:00:05:000 | 3868.0 | 14.07 | 324.6          | 10.81       |    11.7254 |
| 0:00:05:239 | 3977.0 |  13.4 | 323.0          | 10.86       |    11.7254 |
| 0:00:05:479 | 4080.0 | 13.11 | 322.0          | 10.96       |    11.6862 |
| 0:00:05:714 | 4162.0 | 13.17 | 326.0          | 10.87       |    11.6862 |
| 0:00:05:953 | 4268.0 |  13.2 | 329.6          | 10.79       |    11.6862 |
| 0:00:06:192 | 4355.0 | 13.17 | 330.5          | 10.80       |    11.6862 |
| 0:00:06:430 | 4462.0 |  12.8 | 330.1          | 10.72       |    11.7254 |
| 0:00:06:667 | 4555.0 | 12.85 | 327.2          | 10.64       |    11.7254 |
| 0:00:06:910 | 4644.0 |  12.8 | 325.3          | 10.52       |    11.7254 |
| 0:00:07:145 | 4760.0 | 12.48 | 323.6          | 10.46       |    11.6078 |
| 0:00:07:389 | 4821.0 | 12.74 | 322.5          | 10.39       |    11.7254 |
| 0:00:07:625 | 4911.0 | 12.27 | 314.3          | 10.38       |    11.7254 |
| 0:00:07:865 | 5001.0 | 12.13 | 314.1          | 10.36       |    11.7254 |
| 0:00:08:105 | 5092.0 | 11.87 | 312.9          | 10.36       |     11.647 |
| 0:00:08:342 | 5176.0 | 11.75 | 306.4          | 10.34       |    11.6862 |
| 0:00:08:580 | 5261.0 | 11.43 | 299.5          | 10.31       |    11.6862 |
| 0:00:08:814 | 5344.0 | 11.37 | 299.7          | 10.30       |    11.6862 |
| 0:00:09:052 | 5418.0 | 11.26 | 295.8          | 10.28       |    11.6862 |
| 0:00:09:286 | 5496.0 | 11.05 | 294.5          | 10.28       |    11.6862 |
| 0:00:09:523 | 5578.0 | 10.65 | 284.6          | 10.23       |    11.6862 |
| 0:00:09:762 | 5640.0 | 10.39 | 281.4          | 10.18       |    11.7254 |
| 0:00:10:001 | 5721.0 | 10.21 | 277.4          | 10.15       |    11.7254 |
| 0:00:10:239 | 5783.0 | 10.27 | 273.9          | 10.13       |    11.7254 |
| 0:00:10:477 | 5848.0 | 10.56 | 270.2          | 10.07       |     11.647 |
| 0:00:10:716 | 5918.0 | 10.53 | 266.6          | 10.01       |    11.7254 |
| 0:00:10:955 | 5974.0 | 10.74 | 263.6          | 9.967       |    11.7254 |
| 0:00:11:192 | 6048.0 | 10.85 | 259.2          | 9.900       |    11.7254 |
| 0:00:11:425 | 6112.0 | 10.71 | 254.7          | 9.802       |    11.7254 |
| 0:00:11:659 | 6164.0 | 10.74 | 244.8          | 9.787       |    11.7254 |
| 0:00:11:895 | 6229.0 | 10.97 | 75.03          | 9.774       |    11.7254 |
| 0:00:12:130 | 6187.0 |  9.81 | 245.3          | 9.942       |    11.7254 |
Old 04-21-2009, 04:12 AM   #15 (permalink)
Trader Rating: (20)
^^^^teach me your ways
:bowdown:
nice job man.
Page generated in 0.19293 seconds with 13 queries
