Old 11-04-2009, 12:07 AM   #1 (permalink)
SRTrent's Avatar
Member Number: 65861
Default too lean in higher gears...
Ok so since my boost starts at around 15-16psi in 2nd it's ok but when I hit 3rd it jumps up to like 18psi then in 4th it hits like 19psi causing it 3rd gear and 4th gear to be too lean. This really messes up the tune I think. Is there any way I can get it to hold 16-17psi in 2nd, 3rd, 4, and 5th gear? Any way to adjust the wastegate so it holds the same boost in all gears? What should I get for fuel if I wanna run 18-19psi just injectors or a return line and/or fuel pump too?
SRTrent is offline   Reply With Quote
Old 11-04-2009, 07:42 AM   #2 (permalink)
duster360's Avatar
Member Number: 45182
Post a datalog so everyone can see what you're talking about.
18-19psi is about where you want it.
Regardless of if you 'think' its lean, you should add fuel only in response to Knock. Adding up to 10%-15% Fuel is not out of the question.
2nd gear in my car breaks the tire loose at about 5K so its the quick rise in RPM pulls the boost back quickly to about 15psi from the initial 19psi spike. If you look at your RPM curve compared to your Boost curve you'd see the Boost lvl is very simliar at the same RPM. Since 2nd gear raises RPM so quickly it just looks like the boost level is different.
Old 11-04-2009, 08:42 AM   #3 (permalink)
SRTrent's Avatar
I don't have a laptop and my scangauges aren't working right now all I have is my wideband hooked up and sitting on the dash. In 3rd-4th gear my wideband reads up to 12.5ish. If I want more fuel should I get injectors?
Old 11-04-2009, 09:06 AM   #4 (permalink)
duster360's Avatar
lets try this again:
Use the DSP to datalog You don't need a laptop, the DSP will save a log internally.
DON'T waste money on injectors,,ADD FUEL WITH THE DSP, BUT ONLY IF THERE IS KNOCK!!!
Old 11-04-2009, 12:34 PM   #5 (permalink)
SRTrent's Avatar
but what if I wanna run 20psi? stock fuel system isn't gonna do that is it? how do i datalog with the DSP?
Old 11-04-2009, 01:11 PM   #6 (permalink)
duster360's Avatar
A breif 20psi spike is not an issue for the fuel system.
READ the Predator manual to learn how to datalog.
Old 11-04-2009, 03:40 PM   #7 (permalink)
Gizmodo's Avatar
Member Number: 22931
If you want to hold 20psi you are using the wrong turbo.
Gizmodo is offline   Reply With Quote
Old 11-04-2009, 04:02 PM   #8 (permalink)
SRTrent's Avatar
It doesnt say how in the manual that i got
Old 11-04-2009, 07:21 PM   #9 (permalink)
SRTrent's Avatar
can anyone please tell me how to? i don't have adobe so i can't download pdf files and in the predator manual there isn't anything to show about data logging
Old 11-04-2009, 07:23 PM   #10 (permalink)
SRTrent's Avatar
I'll be going big turbo sometime but for now I want to get the most out of the stocker since I think I'm almost there and then go to school for now.
Old 11-04-2009, 07:29 PM   #11 (permalink)
Adionik's Avatar
Member Number: 51197
Trader Rating: (25)
2nd gear is not a gear to care about tuning wise...seriously. I tuned in 3rd gear and 2-4 is perfect. Just tune properly in 3rd
or 16 whatev
WTB: LCA bushings
Adionik is online now   Reply With Quote
Old 11-04-2009, 07:41 PM   #12 (permalink)
SRTrent's Avatar
yeah I usually do 2nd-4th but really watch in 3rd and 4th and record on the scangauges
Old 11-04-2009, 07:43 PM   #13 (permalink)
Chief's Avatar
Member Number: 61336
tune in 3rd.
unless you have wheel spin in 3rd
than i suggest 4th
Built bottom end
strapped BC and CP
HTA 60
PTP when you fedex man gettin this block?
Chief is online now   Reply With Quote
Old 11-04-2009, 07:47 PM   #14 (permalink)
Adionik's Avatar
Trader Rating: (25)
Quote: Originally Posted by Chief View Post
tune in 3rd.
than i suggest 4th
Haha yeah, big turbos and 3rd ain't too fun...well after the lag
Old 11-04-2009, 07:48 PM   #15 (permalink)
Chief's Avatar
trueeee.
Page generated in 0.15790 seconds with 13 queries
