Old 11-01-2009, 01:15 PM   #1 (permalink)
Brian87gt's Avatar
Member Number: 4097
Default To those with a custom tune
When you had your car custom tuned by a CMR dealer was anything changed in the handheld. I was wanting to do some tweaking on the street and noticed that the WOT fuel and WOT spark settings were changed in the handheld. Shouldn't they all be at zero since it was tuned using the software? Thanks
Brian87gt is offline   Reply With Quote
Old 11-01-2009, 02:50 PM   #2 (permalink)
93stang434's Avatar
Member Number: 49690
My hand held was zeroed out.....you sure they used CMR.
E1 w/ported 3" anti-surge cover,LCR fully ported ext.gated exh mani,3" o2 housing,3"SEE,N2MB boost box,
S2 injectors,diablosport predator,coolingmist w/m
255 pump,rewire,bottleneck mod,returnline
MPx bfmic,55 t-body,180 t-stat,DCR oil restrictor
Best E.T 12.12 Best MPH 118.71 DR's,full weight no n2o
Tuned by Nemo@Rage-Tek & myself http://www.srtforums.com/forums/f146...charts-480643/
93stang434 is offline   Reply With Quote
Old 11-01-2009, 05:39 PM   #3 (permalink)
Brian87gt's Avatar
Member Number: 4097
Unless it wasn't zeroed out when I gave it to them, but you would have thought they would have checked that. If I try to zero it out now it'll screw up the custom tune. Correct???
Old 11-01-2009, 06:21 PM   #4 (permalink)
Kason23's Avatar
Member Number: 34502
Trader Rating: (20)
it should be zero'ed out.
Tuned By TDSAaron!!
My Goal: 100+Mph in the 1/8
Old 11-01-2009, 08:15 PM   #5 (permalink)
93stang434's Avatar
When your on the main menu screen and you select performance tune you should have two options 1.Diablo tunes
2.custom tunes
If thats not the case i would say you have a problem and they tuned using the hand held.
Old 11-01-2009, 08:25 PM   #6 (permalink)
Brian87gt's Avatar
Member Number: 4097
2.custom tunes
I have those 2 options, but it gives me the option to modify or install the tune. When I click on modify some of the parameters have been changed. For example , under timing from 6-k it's set at -10 degrees. So if I ever wanted to pull more timing for that range i'm pretty much screwed.
Old 11-01-2009, 08:31 PM   #7 (permalink)
Xx_R/T_xX's Avatar
Member Number: 18749
it should be zero'd out on everything.IF changes are made on a tune,those settings get changed on the dsp and tune itself
BIG TURBO!
Old 11-02-2009, 05:34 AM   #8 (permalink)
turbo666's Avatar
Member Number: 25206
Trader Rating: (31)
Whenever ever you go to install a custom tune it will ask you to return settings to default, at that point they should have clicked yes and done so.
Nigel
04 Srt-4-AGP Borg Warner S360-RS, E85, and MUCH MORE coming soon...
7.493@99.56<-- granny shifting on 30r with 93/meth <--OLD SETUP!
FIRST TO MAKE BIG TURBO PCM BOOST CONTROL WORK ON DIABLO!
For custom tuning, installs, and transmission rebuilds PM me!
www.trudynosports.com
turbo666 is online now   Reply With Quote
Old 11-02-2009, 08:54 AM   #9 (permalink)
duster360's Avatar
Member Number: 45182
Yes
If a tune had previous heandheld changes made to it and then is reflashed for whatever reason, the Predator will ask you if you want to RESET the settings = zero out the handheld changes.
If a CMR had the tune out and made changes, you almost always want to say YES, return the setting to default.
duster360 is online now   Reply With Quote
Old 11-02-2009, 10:34 AM   #10 (permalink)
ptperformance's Avatar
Member Number: 25514
Trader Rating: (567)
CMR dealers can only see what you send them, if you send the tune with changes we will see these and work around them or zero them out with our cal file. Problem being, you hand held saves the changes and we cannot zero those out. You need to reset the parameters when you load the custom tune, this way you are starting with a "fresh" tune.
Home of the DSP Tuned 657 WHP SRT4 Neon, 593 WHP SRT4 Caliber and the fastest stock turbo DSP tuned SRT4
DSP or Trinity
Old 11-02-2009, 11:50 AM   #11 (permalink)
Member Number: 53360
The problem is he went and had a cmr dyno tune done, not canned. Also did 3rd gear dyno pulls and tuned a/f by tailpipe sniffer. I thought this was odd.
2004 SRT-4 Murdered, Built, Cammed, GT35R, Meth, N2O
2003 Dakota R/T Charcoal, Stock
mjennings2 is offline   Reply With Quote
Old 11-02-2009, 01:48 PM   #12 (permalink)
Kason23's Avatar
Trader Rating: (20)
Yea I had NO luck with sniffers. They always ran alot leaner then my wideband. I would of made sure they tuned via wideband.
Old 11-02-2009, 04:00 PM   #13 (permalink)
93stang434's Avatar
Rage tunes with a sniffer and the difference wasn't much compared to the wide band, maybe .1-.2.If you've got a leaky exhaust i would say the sniffer would be a bad idea.
Old 11-02-2009, 04:28 PM   #14 (permalink)
Sniffer on my car reads .9-1.2 off. I dont have any leaks?
Old 11-02-2009, 04:36 PM   #15 (permalink)
Kason23's Avatar
Trader Rating: (20)
Yea mine was reading a good .5-1 point leaner also. And I had zero leaks
Page generated in 0.15186 seconds with 13 queries
