Old 01-12-2009, 08:31 PM   #1 (permalink)
funatnight's Avatar
Member Number: 69676
Default Stock car- just getting started
I have a stock car that I bought used. It only has a rice plate.
Looking to find the simplest and most reliable way to make some extra power.... nothing extravagant.
1. What can be expected from just using the DSP without any changes?
2. What is the next step after the DSP? WGA? Wideband?
3. What is the benefit of the WGA?
4. What is the benefit of the wideband? Does it work in conjunction with the DSP? How does this connect to the car?
I have built several old school V8 drag cars, but this is my first ever dealing with these new fangled computerized car thingies
Thanks in advance
funatnight is offline   Reply With Quote
Old 01-13-2009, 07:01 PM   #2 (permalink)
letxen3's Avatar
Member Number: 41680
Trader Rating: (20)
read some of the sticky post that are in here above very good information on there but i will try to anwer your questions in red....
~increased boost to 19 psi spike and 15psi hold and a afr of about 11.9. every car is different so these numbers can vary do to things like wear and tear on parts and or boost leaks etc.
~once you get a predator your now going beyond your average bolt ons, ur in the tuning part and reliable monitoring gauges are a must yes get a wideband to monitor air fuel ratios.
~stock wga is fine though the word is the foward motion wga (fm wga) is better for pcm controlled load response but try your stocker 1st if you feel you dont like it change it i guess.
~benefit of the wideband is you can watch your air fuel ratios make sure your car is not running too lean nor too rich. wideband will be a separate gauge from the predator it will help you watch your afr's if you want to start to fine tune things incase the can tune from the predator is not doing it for you. the wideband has a sensor that gets installed in your exhaust system before your cat. the predator gets plugged in to your OBDII port and you flash the tune in and then unplug it.
Thanks in advance
oh and welcome to the world of computer controled cars and fuel injection
James | 2004 PT Cruiser 5spd
AEM | Aeroforce | AMX | AutoMeter | DiabloSport | Dynamic Turbo | HKS | K&N | Kobe | Mopar | MSD | Needswings | Nexen | NGK | Perrin | PTPerformance | Rage-Tek | Spec | Zeitronix
letxen3 is offline   Reply With Quote
Old 01-13-2009, 09:18 PM   #3 (permalink)
funatnight's Avatar
GREAT response! I have been looking around here a lot, I have read through most of the posts in this section, but they all seem very technical, a little beyond my basic knowledge. Thanks for helping out with the basics!
I am assuming that we are trying to balance several things at once and the computer is doing it's best to fight us?
1- AFR
2- Boost
3- Timing
All the while we are doing our best to keep the knock sensors at bay?
It would seem that we can control 2 out of the 3, the 3rd is up to the computer.
Am I looking at this logically?
This is a world away from dual dominators and sheet metal manifolds with fogger systems!
Old 01-13-2009, 11:31 PM   #4 (permalink)
letxen3's Avatar
Trader Rating: (20)
i wouldnt say the computer is fighting us its more like projecting the engine. if it detects pinging (knock) with the knock sensors it will retard timing and or lower boost and or inject more fuel.
before it was all about hiding boost with external boost/air fuel controllers, now with using the stock computer we are now over riding the maps and telling the pcm to run more power, but at the same time the computer still does things to keep things safe to a certian extent.
Old 01-14-2009, 07:56 AM   #5 (permalink)
funatnight's Avatar
That explains a lot of things to me.
Once we have control of the PCM via the DSP, what is the first roadblock that we come up against? Lack of fuel? Not enough boost?
Old 01-14-2009, 10:23 AM   #6 (permalink)
letxen3's Avatar
Trader Rating: (20)
no road blocks except the need for even more power more parts and maybe a few speeding tickets and or needing to buy a bigger turbo etc.
Old 01-14-2009, 11:14 AM   #7 (permalink)
Bebo's Avatar
Member Number: 46331
^^^what he said.
Yeah pretty much what you do is get a wideband & the Predator. Drive it with just the wideband & get used to how it works then (before you even load a tune) run a datalog with the predator so you know what things look like stock. Then, load the 93oct perf tune & datalog again. Note any changes in AFR (with your wideband) & compare the stock datalog to your performance tuned datalog (you'll feel a notable difference while driving). Read up on AFR's, knock, & just basic tuning. If you take it slow you will see what effect this has on that without it being so overbearing & boom.
Tuning will net you more of a speed gain than a HP/TQ gain (if that makes any sense). After you've figured out how to tune then you'll be comfortable enough to upgrade injectors & turbos on a tuning standpoint.
Also, don't waste your money on an intake unless you need one for a larger turbo.
Quote: Originally Posted by njshift View Post
I f*cking love this car. Some of the owners I could car less about.
Bebo is offline   Reply With Quote
Page generated in 0.16268 seconds with 13 queries
