Old 10-23-2009, 04:18 PM   #1 (permalink)
KrazyRdR83's Avatar
Member Number: 55270
Trader Rating: (40)
Question Stage 2 with DSP going crazy
Ok, I'm posting this for a friend of mine. I went with him to do some pulls/logs...and this is what happened.
We did two pulls, both pulls were exactly the same. Starting in 3rd gear in both pulls, a/f jump up to 12.5 and stay above 12. Starts to knock like crazy, and rises as the rpm's rise. Once in 4th, everything settles down. A/f's drop down to high 10's low 11's, no knock, and the car really moves then. Boost, his gauge says 20 drops to 15 to redline.
Any ideas on why this is going on? Mods are full stage 2 w/o toys, 3" downpipe (catless), mopar exhaust, AGP wga off pcm controlled boost, cold air intake, fuel pump rewire, i believe that's it.
first pull
Deposit Files
second pull
Deposit Files
04 Neon SRT-4 - lifetime project
99 R1 - DD
02 Night Train
04 XL883
00 B5 Passat - POS!
KrazyRdR83 is offline   Reply With Quote
Old 10-23-2009, 07:23 PM   #2 (permalink)
sfla_srt4's Avatar
Member Number: 61295
Trader Rating: (13)
see diablo forums for my reply...
sfla_srt4 is offline   Reply With Quote
Old 10-23-2009, 07:24 PM   #3 (permalink)
lyncoo's Avatar
Member Number: 43166
Trader Rating: (92)
was it set up for a s2 wga
AGP S256 FS
Old 10-23-2009, 09:19 PM   #4 (permalink)
KrazyRdR83's Avatar
Trader Rating: (40)
just did....
just the 93oct tune in there now...the 9r17crom
Old 10-25-2009, 10:56 AM   #5 (permalink)
druSRT's Avatar
Member Number: 46523
Id say take the 93 tune off the car and just run the modified stock s2 tune. Then make adjustments on the stock s2 tune.
druSRT is offline   Reply With Quote
Old 10-25-2009, 11:42 AM   #6 (permalink)
Philth's Avatar
Member Number: 46647
Trader Rating: (29)
I didn't know the DSP came with this option? Only the 93 tune...
Old 10-25-2009, 11:43 AM   #7 (permalink)
lyncoo's Avatar
Trader Rating: (92)
yeah you can mod the stock tune
Old 10-25-2009, 02:12 PM   #8 (permalink)
duster360's Avatar
Member Number: 45182
1) ACT and Ambeint temps are unrealistically HOT. I presume he's using a pos Hot Air intake. I'd get them to more reasonable/correct levels.
2) Why aren't you using the 9r18?
3) 3rd gear Openloop F/A is at the 93tune "stock" level of 11.77 but COT is kicking in in 4th(when EGT over 1740) and droping the OLFA and dumping fuel so the Knock goes away.
Update to the 9r18 tune and add enough fuel(~5%) to keep the reported A/F under 12.0 and you'll be fine.
Old 10-25-2009, 02:14 PM   #9 (permalink)
duster360's Avatar
Not the best idea.
The 93 tune can be tweeked in this case to work very well.
Old 10-25-2009, 02:16 PM   #10 (permalink)
duster360's Avatar
?????? You can 'modify' the tune of what ever PCM you have.
Old 10-25-2009, 02:46 PM   #11 (permalink)
Philth's Avatar
Trader Rating: (29)
I thought he was implying that there was a seperate modified S2 tune thats preloaded.
Old 10-25-2009, 04:05 PM   #12 (permalink)
KrazyRdR83's Avatar
Trader Rating: (40)
2) Why are you usuing the 9r18?
I think he does have a short ram, I'll have to ask though.
He's using the 9r17 crom, COT has not been turned off or anything of the sort. i told him to update to the 9r18 and we'll take it from there. Not sure if he's done it.
Old 10-25-2009, 11:47 PM   #13 (permalink)
druSRT's Avatar
Not the best idea.
Just wondering what advantages a s2 car would have running a modified 93 tune vs a modified s2 tune. I thought the 93 tune works better on a s0 pcm?
Old 10-26-2009, 07:42 AM   #14 (permalink)
duster360's Avatar
There are more significant changes to the S0/S1 PCM with the 93tune than with a S2 but there are several changes to all PCMs that the end user does not direct see. Sensor limits, Airflow limits, Torque modifiers and limiters, ect.
Imo there is value in using a 93tune as a base to apply your desired changes to than the stock S2 tune.
Old 10-26-2009, 03:14 PM   #15 (permalink)
druSRT's Avatar
Intersting. Does those changes effect a s2 with toys on hom?
Page generated in 0.15833 seconds with 13 queries
