Old 08-19-2009, 01:54 AM   #1 (permalink)
Member Number: 52541
Default S0 + Map clamp + DSP ?
Well, I currently have a S0 pcm map clamped, obiously to lean it out and hid the 20psi spike. Im getting a DSP so since im holding off on getting a 3bar map, would it be ok to Clamp the pcm at 17psi, and then use dsp to tune from there? The reason for this is that so when the pcm sees the 20psi spike it doesnt pull timing or freak out.
or will the 93 tune on dsp eliminate the issues above stock map levels?
___________________________
2003 Dodge Srt4 - DSP, Meth & Boltons
dabezt1 is offline   Reply With Quote
Old 08-19-2009, 07:58 AM   #2 (permalink)
Panco469's Avatar
Member Number: 60156
I remove the clamp and the car is running fine with the dsp. I'm spiking 26.22psi.
Panco469 is offline   Reply With Quote
Old 08-19-2009, 08:08 AM   #3 (permalink)
duster360's Avatar
Member Number: 45182
Quote: Originally Posted by dabezt1 View Post
Well, I currently have a S0 pcm map clamped, obiously to lean it out and hid the 20psi spike. I'm getting a DSP so since im holding off on getting a 3bar map, would it be ok to Clamp the pcm at 17psi, and then use dsp to tune from there? The reason for this is that so when the pcm sees the 20psi spike it doesnt pull timing or freak out.
Remove the Clamp. Its completely unneeded with the DSP. With the DSP 93tune, you will spike 20psi with no problem using the stock sensors. The PCM will NOT "pull timing or freak out".
Old 08-19-2009, 08:35 AM   #4 (permalink)
bene's Avatar
Member Number: 53801
Trader Rating: (45)
ewtazsdgtasgdssa
bene is offline   Reply With Quote
Old 08-19-2009, 08:44 AM   #5 (permalink)
JPG
JPG's Avatar
Member Number: 41528
Trader Rating: (26)
guyss... 22psi hold on stock turbo? no porting no bigwheel not ext gate? you realize its not doing anything to help right? you realize its way past its efficiency range and you are just blowing hott air and the turbo is struggling?
16psi hold @ redline. thats it. stop wasting your time and breaking your parts.
Quote: Originally Posted by Flame View Post
Shun the non believer!!!!
SSHhhhhhhhhhhhhhhhhhuuuuuuunnnnnnnn!!!!
JPG is offline   Reply With Quote
Old 08-19-2009, 09:11 AM   #6 (permalink)
duster360's Avatar
Quote: Originally Posted by bene View Post
the DSP 93 tune you cannot run over 18 psi on.
Why not?
Guys do it all the time with the stock wga and the 93 tune. Its completely normal.
Old 08-19-2009, 09:18 AM   #7 (permalink)
duster360's Avatar
No stock turbo will not hold 22psi at 6Krpm, but a breif spike is just fine if not desirable.
I've only see 1 log of anyone holding more than 16psi and it was 16.001, most guys are in the 12-15psi range regardless of which wga they're using and despite thier claim.
A TD04LR-15 will choke at right around 20-22psi,,,,,,So 22psi spkie is hardly "way past its efficiency range and you are just blowing hott air and the turbo is struggling"
Old 08-19-2009, 09:54 AM   #8 (permalink)
bene's Avatar
Trader Rating: (45)
dgafzdfffffffffffffffffffffffffffffffff
Old 08-19-2009, 10:29 AM   #9 (permalink)
duster360's Avatar
rage left the fuel cut on their 93 tunes so you wouldnt turn up the boost to a unsafe level and blow your engine.
Rage is not "the DSP 93 tune"
The DSP 93tune works great at 20psi.
PLease edit your post to correct the misinformation
Old 08-19-2009, 01:19 PM   #10 (permalink)
I know the turbo wont hold anywhere near 20psi, but i want to spike somewhere around that. The meth/water injector helps alot with the hot air. Im also using a agp wastegate.
I just wanted to make sure it didnt start pulling timing, but i guess ill have to test it out and scan it
Old 08-26-2009, 07:02 PM   #11 (permalink)
jessebeachusmc's Avatar
Member Number: 70610
Trader Rating: (12)
so you dont need a map clamp when using the dsp you only need the tip sensor?
AGP borg warner s256 powered
jessebeachusmc is online now   Reply With Quote
Old 08-26-2009, 08:18 PM   #12 (permalink)
duster360's Avatar
Yes thats correct
Old 08-26-2009, 08:23 PM   #13 (permalink)
Trader Rating: (12)
why is that? i dont get it. so basically me buying a 3bar map will be useless for running over 18 psi on a bigger turbo like the s256 and all you need is the tip sensor?
Old 08-26-2009, 08:31 PM   #14 (permalink)
duster360's Avatar
No,,,,,,,,,,
Stock turbo = stock sensors are fine over 20psi because it falls quick enough under the MAP's max.
Any other aftermarket turbo that can sustain boost over 19psi should use a 3bar MAP AND TIP.
Old 08-26-2009, 08:59 PM   #15 (permalink)
Trader Rating: (12)
Quote: Originally Posted by duster360 View Post
No,,,,,,,,,,
alright thats what i thought. thats why i was confused.
