Old 10-10-2009, 04:51 PM   #1 (permalink)
Adionik's Avatar
Member Number: 51197
Trader Rating: (25)
Default Return Line PSI
Just curious to what those with return lines have their fuel pressure set to
I left mine stock after installing my return line because I was too lazy to tune all over again
or 16 whatev
WTB: LCA bushings
Old 10-10-2009, 04:58 PM   #2 (permalink)
ptperformance's Avatar
Member Number: 25514
Trader Rating: (567)
Boost base only, this seems to work the best with the DS software. You can do a manifold based set up, but tuning the transition from 0 vacuum can get a little tricky.
Home of the DSP Tuned 657 WHP SRT4 Neon, 593 WHP SRT4 Caliber and the fastest stock turbo DSP tuned SRT4
DSP or Trinity
Old 10-10-2009, 09:36 PM   #3 (permalink)
Member Number: 10107
Got mine setup 58 psi stock with the boost reference hooked up and I pulled almost 40 percent and it was in the 10s and then I added meth and now its like in the high 9s and 10s Need to get a tune bad.
soon2bsrt is offline   Reply With Quote
Old 10-11-2009, 06:40 PM   #4 (permalink)
93stang434's Avatar
Member Number: 49690
Mines at 58psi also with 1:1 regulator, without the tune it was rich as hell.
E1 w/ported 3" anti-surge cover,LCR fully ported ext.gated exh mani,3" o2 housing,3"SEE,N2MB boost box,
S2 injectors,diablosport predator,coolingmist w/m
255 pump,rewire,bottleneck mod,returnline
MPx bfmic,55 t-body,180 t-stat,DCR oil restrictor
Best E.T 12.12 Best MPH 118.71 DR's,full weight no n2o
Tuned by Nemo@Rage-Tek & myself http://www.srtforums.com/forums/f146...charts-480643/
93stang434 is offline   Reply With Quote
Old 10-11-2009, 07:10 PM   #5 (permalink)
bene's Avatar
Member Number: 53801
Trader Rating: (40)
how much does the PSI rise with the boost only source? thats how mines hooked up.
just say on 20 turbo psi.
bene is offline   Reply With Quote
Old 10-11-2009, 07:47 PM   #6 (permalink)
TDSAaron's Avatar
Member Number: 68381
We like to set ours up 43.5psi with boost source only. That is if the injectors are sized correctly.
Aaron Lail
Custom EFI Tuning
Diablo Sport CMR Tuner
www.TruDynoSports.com
"Let me tell you how much power your really making"
TDSAaron is offline   Reply With Quote
Old 10-11-2009, 07:53 PM   #7 (permalink)
turbo666's Avatar
Member Number: 25206
Trader Rating: (31)
Fuel pressure will rise another 20psi. The average regulator is on a 1:1 ratio, so every PSI of boost will cause fuel pressure to increase 1 PSI.
Nigel
04 Srt-4-AGP Borg Warner S360-RS, E85, and MUCH MORE coming soon...
7.493@99.56<-- granny shifting on 30r with 93/meth <--OLD SETUP!
FIRST TO MAKE BIG TURBO PCM BOOST CONTROL WORK ON DIABLO!
For custom tuning, installs, and transmission rebuilds PM me!
www.trudynosports.com
Page generated in 0.16344 seconds with 13 queries
