Old 01-12-2009, 12:09 PM   #1 (permalink)
Chief's Avatar
Member Number: 61336
Trader Rating: (13)
Default NOOB DS go it today help please
Just got my ds today and was able to log some runs, did not change a thing. Seems like my turbo psi is not working alog with my afr. Showing like 9.8? My wideband is in 11's the whole time? WTF? Did all the updates. Look below at my mods. How do you post logs?I have logs but have no clue how to post them on the fourm. Heres some numbers 6100 rpm Im at 9.4 afr 203f ect, map use 27.6, base spark 23.5, act spark 33, 1/1 long term adap -5, My turbo baro pso is always reading 14.6? amp temp 68, spark adj 9.5 and why does me thro pos say 3.863 V ?
first time really looking at this stuff and tunning. Before i just watch the wideband and played with my agp wga, this is a little more involved ll. Any help please
Built bottom end
strapped BC and CP
HTA 60
"PTP, where fail happens......."
Chief is offline   Reply With Quote
Old 01-12-2009, 12:24 PM   #2 (permalink)
4TEHW's Avatar
Member Number: 5620
If you have a power supply and PC data cable, you can hook the Predator up to your PC and pull the log file using the data viewer. From there, you can then e-mail me your log and I'll host it for you. There's more information about that in my signature links, if you're interested.
As for the rest, it's not going to log your actual A/Fr. I'm sure duster360 can add more on that topic. Your boost pressure can be calculated in a couple ways that I know of. I use the method of 'map to use' - 'baro'. There's also 'map to use' - ('pratio'/'map to use'). Something like that, anyway.
Try to get your log file to me and we'll be able to take a look at it.
4TEHW is offline   Reply With Quote
Old 01-12-2009, 01:09 PM   #3 (permalink)
Chief's Avatar
Trader Rating: (13)
Ok got it sent out, hope you can help me out.
Old 01-12-2009, 01:14 PM   #4 (permalink)
4TEHW's Avatar
Member Number: 5620
I'm not an expert, but I'll do my best. And this way, others can also view your log.
Edit: Ok, your log file can be found here.
Old 01-12-2009, 01:44 PM   #5 (permalink)
Chief's Avatar
Trader Rating: (13)
thanks man, Just ran out of meth today, and got no more. So im gonna turn off the meth and see what i can do w/o it. Turning the boost back down and ill do some logs tomrrow w/o meth. What do you think about the first log i sent you?
Old 01-12-2009, 01:47 PM   #6 (permalink)
4TEHW's Avatar
Member Number: 5620
Checking it out now. I'm at work, so it's slow going. I'll post back up when I've had a chance to look it over entirely.
Old 01-12-2009, 02:24 PM   #7 (permalink)
Chief's Avatar
Trader Rating: (13)
Awsome, Gonna try to get some meth tomrrow, I just came to work on 19 psi spike and good afrs, added 2% fuel on 3-4k 4-5k Seem to stay below 12's till 4500 than hit 12.1 Seem pretty smooth to. But wanna run meth, adds so much more pulling powa! But might mess around with it till than.
Old 01-12-2009, 02:27 PM   #8 (permalink)
Chief's Avatar
Trader Rating: (13)
2 other things, I have a agp wga so that means the pcm is not controlling it there for the boost controll on the dsp wont effect it at all? And two, The netural rev limiter dose NOT work lol. Put it to like 3k just to see and well she reved past 3k?
Old 01-12-2009, 09:01 PM   #9 (permalink)
Chief's Avatar
Trader Rating: (13)
Tonight (colder) 11.5 all the way up to like 4500rpm than all of a sudden jumps to like 12.5 and rises. ??? More fuel? Im going to try it, but may just need to bring the boost back down. was hitting 21 psi
Old 01-13-2009, 09:11 AM   #10 (permalink)
Chief's Avatar
Trader Rating: (13)
http://www.whitehack.org/Predator%20Logs/Chief.log
Any help? this was done on stock tune with meth? Dint mess with anything.
Old 01-13-2009, 11:28 AM   #11 (permalink)
Chief's Avatar
Trader Rating: (13)
very frushtrated, Cant seem to get this thing to run stronger if anything i get it to run worse?!?!?! Watching my afrs trying to add and pull fuel but dosent seem to effect the afrs much at all, tried messing with a little timming dint notice a difference?
Old 01-13-2009, 11:29 AM   #12 (permalink)
Chief's Avatar
Trader Rating: (13)
Well im lossing my job this friday we just got laid off today, Looks like the ds is going to get sold now. I want to keep the srt, dont want to losse her, so the ds had got to go. If anyone wants dibs before it goes on the FS pm asap.
Old 01-13-2009, 04:18 PM   #13 (permalink)
4TEHW's Avatar
Member Number: 5620
Gah...that sucks dude, sorry. I ended up going home early yesterday. I've been pretty sick since Saturday. Took today off too. I'm sure your Predator will sell fairly quick.
Page generated in 0.19324 seconds with 13 queries
