Old 11-07-2009, 12:22 PM   #1 (permalink)
Member Number: 75447
Default newest log
well i think this is my best one thus far.
Deposit Files
Aimois is offline   Reply With Quote
Old 11-08-2009, 01:49 AM   #2 (permalink)
ptperformance's Avatar
Member Number: 25514
Trader Rating: (567)
Looks pretty good, seems that you could add a bit of timing and the TQ tables shoud be reading higher but I don't know what your mods are. I would also take a look at giving a bit more back to the injectors rescale. Seems that your always adding fuel to your fuel table when in closed loop. Not a bad tune, hows it run?
Home of the DSP Tuned 657 WHP SRT4 Neon, 593 WHP SRT4 Caliber and the fastest stock turbo DSP tuned SRT4
DSP or Trinity
Old 11-08-2009, 05:36 PM   #3 (permalink)
it runs absolutely ok, and where do you see i can add timing? And what do you mean about injector rescale? Sorry for the newb questions
Old 11-09-2009, 07:54 AM   #4 (permalink)
If you watch the knock sensor settings you get a quick count of knock, just add 1 degree of timing (advance) at that RPM range and that should clear that up.
Are you running on a custom CRM dealer tune? That is what I mean by rescale of the injector. You car is adding fuel to the fuel trims indicating that you injectors are either clogged, you have a clogged fuel filter or your "rescale" (if you got one) is off. Hope this helps.
Old 11-09-2009, 08:04 AM   #5 (permalink)
lyncoo's Avatar
Member Number: 43166
Trader Rating: (92)
looks like your coming right along aimois
AGP S256 FS
lyncoo is online now   Reply With Quote
Old 11-09-2009, 04:28 PM   #6 (permalink)
Yeah ima tryin =D
Old 11-09-2009, 08:18 PM   #7 (permalink)
duster360's Avatar
Member Number: 45182
That's quite a big leap to conclude that +2.7% LTFT = fuel clogg.
98% of guys have 0%LTFT at WOT. The few that I've seen show -1%-2%. imo its more of just a nuisance than a reiable indicator. Here's why:
Since LTFT is based off the upstream O2 sensor, everyone knows the narrow band O2 sensor sucks if richer 14.3 or leaner than 14.9. So I could care less if the PCM thinks it needs to add or remove fuel at WOT because the info its basing this decision is completely inaccurate.
Whenever you see LTFT at WOT. immediately clear it with a battery disconnect and retest.
Old 11-09-2009, 09:14 PM   #8 (permalink)
duster360's Avatar
Timing is pretty high but that's because the boost is low. Boost is about 3-4psi lower than it should be past 4500rpm(for 93tune).
Based off the timing, boost and Open Loop FA, it looks like the stock tune.
Old 11-10-2009, 07:25 AM   #9 (permalink)
well what do you recommend i try adding boost wise and what should i do with the timing?
Page generated in 0.13741 seconds with 13 queries
