Old 11-02-2009, 01:47 PM   #1 (permalink)
Member Number: 75638
Default New Dsp Big Question???
Heres My Question I Have A Agp Wga And Was Going To Install The 93 Per Tune Tonight What Else Would I Need To Tweek For The Wastegate Not Being Stock? Its Stil Pcm Controlled
srtofdeathga is offline   Reply With Quote
Old 11-02-2009, 04:08 PM   #2 (permalink)
Gizmodo's Avatar
Member Number: 22931
Put the stock WGA back on. There is no need for an aftermarket WGA with the DSP. There really isn't anything to gain. If you keep the AGP, you will need a CMR tuner to adjust the wastegate duty cycle.
Gizmodo is offline   Reply With Quote
Old 11-02-2009, 04:22 PM   #3 (permalink)
thoedsrt4's Avatar
Member Number: 51089
i had the agp wastegate with 93 tune pcm controlled and i was running crasy boost spiking 20 or more in all gears so i put the stock 1 back on runs alot better
thoedsrt4 is offline   Reply With Quote
Old 11-03-2009, 06:52 AM   #4 (permalink)
WELL HERES THE THING I HAVE A STOCK WGA BUT I BOUGHT THIS CAR WITH ONE ALREADY ON IT NOT SURE IF I CAN PUT IT ALL BACK TOGETHER RIGHT
Old 11-03-2009, 07:47 AM   #5 (permalink)
Gizmodo's Avatar
The stock WGA mounts in the same way the AGP does. All you have to do is remove the two bolts holding it on, unhook the arm, and then reverse the process with the stocker. You may have to remove the top heat shield as well.
Old 11-03-2009, 08:26 AM   #6 (permalink)
BUT WHAT ABOUT THE LINES THAT HAVE BEEN REMOVED THERES A GREDDY BOV ALSO HOOKED UP DOES THAT MATTER
Old 11-03-2009, 10:23 AM   #7 (permalink)
Gizmodo's Avatar
What lines were removed? The bov shouldn't matter.
Old 11-03-2009, 10:27 AM   #8 (permalink)
orooso's Avatar
Member Number: 70144
some one needs to learn to not use caps....and maybe use the search??? a wastegate is as easy as changing the oil if not easier......
old car-----98 ACR DOHC 5 speed, close ration tranny, w/ srt exhaust, afx ecu, 52mm tb, 3.0 CAI, solid front mount, flex sides, solid bobble strut, 65% sts by maddog, no p/s or a/c, my best 1/4 15.247 at 90.19
old car---- 98 DOHC 5speed all stock
NEW!!---2005 orange blast SRT-4
Cruise control, MM/tranny inserst, fuel pump rewire, scan gauge, Stg 2 WG, 75 shot
orooso is offline   Reply With Quote
Old 11-03-2009, 10:40 AM   #9 (permalink)
Member Number: 75328
if all the lines are removed, you are not pcm controlled. you can do a search on vacuum lines/diagrams, and you will find the thread that shows all the different ways to route the hoses. you can leave the agp wga on w/ the dsp, u just have to get the waste gate duty cycle (WG DC) adjusted to work properly. there is a group of guys that say they will do it for free, just search for free tunes. i have no experience with the guy, so i cant vouch for his work. also, in the how-to stickies, there is a thread for agp wga install that you can follow in reverse for the stock wga. there is also a thread somewhere w/ how to use agp wga w/ pcm control for dsp. sorry i cant provide you links, i honestly dont feel like searching for the stuff right now. good luck with the car. and search the forums more, u can find answers (often given multiple times) for just about any question you may have.
nfrancis1 is offline   Reply With Quote
Old 11-03-2009, 10:41 AM   #10 (permalink)
yeah, dont use all caps. it means that YOU ARE YELLING if u didnt know. doesnt bother me, but does offend many. and yes, search.
Old 11-05-2009, 05:07 PM   #11 (permalink)
SRTrent's Avatar
Member Number: 65861
So what's the big difference in using the stock WGA and an aftermarket one? I'm using the FM WGA OFF of PCM controlled boost right now. How would the stock one be better and how does it affect the wastegate duty cycle? If I get mine tuned for it then it would be better than stock right?
SRTrent is offline   Reply With Quote
Old 11-06-2009, 09:02 AM   #12 (permalink)
Gizmodo's Avatar
If you aren't letting the PCM control boost it doesn't matter how much you or a CMR dealer tune, the boost won't change.
Old 11-06-2009, 09:04 AM   #13 (permalink)
SRTrent's Avatar
The boost WILL change if I adjust the wastegate though...
Old 11-06-2009, 03:15 PM   #14 (permalink)
Gizmodo's Avatar
You're missing the point. Why screw around with an external boost controller when you have the PCM to do it? The PCM is far more advanced than any electronic boost controller, not to mention an MBC.
Old 11-06-2009, 03:51 PM   #15 (permalink)
SRTrent's Avatar
So you are saying that it would be better to be on PCM controlled boost with the stock WGA rather than OFF or ON PCM controlled boost with an aftermarket WGA?
Page generated in 0.17506 seconds with 13 queries
