Old 11-02-2009, 04:51 PM   #16 (permalink)
Chief's Avatar
Member Number: 61336
what should the tps volts be at closed throttle??? .80 range?
Built bottom end
strapped BC and CP
HTA 60
PTP when you fedex man gettin this block?
Chief is offline   Reply With Quote
Old 11-02-2009, 05:06 PM   #17 (permalink)
Chief's Avatar
my tps wiring is right, it read like .84 i think when closed. Im guessings its my RVT TB gasket. I could not find one first time i painted my intake mani, and harris said rvt works great. Tried it and it did work, but that was over 6 months ago, im thinkin it sprung a leak.
Old 11-03-2009, 01:01 AM   #18 (permalink)
Chief's Avatar
ive tried savin a dashboard to the pids in the stickie, but when i try to bring the dash back up the pids are not all there and some are not even ones i saved? what am i doing wrong?
Old 11-03-2009, 07:51 AM   #19 (permalink)
Gizmodo's Avatar
Member Number: 22931
If I remember correctly my TPS reads .75/.76 when closed.
Gizmodo is offline   Reply With Quote
Old 11-03-2009, 07:51 AM   #20 (permalink)
duster360's Avatar
Member Number: 45182
You saved it in the wrong folder
try Mydocuments
Old 11-03-2009, 09:10 AM   #21 (permalink)
Chief's Avatar
no its in my docs dashboards. They come up, but its not even close to what i saved pid wise?
Old 11-03-2009, 10:26 AM   #22 (permalink)
duster360's Avatar
The dashboard only selects the PIDS available on NEW logs when logging with the laptop. Note: The ONLY way to log EVERY PID on the Dashboard is to use a laptop.
If you try to use the RevB Dashboard on an old log that only contains 50% of the dashboard PIDs, All the logs PIDs will be shown but only those 50% Dashboard PIDs will be selected.
Also under the tab "VIEW"-->"Settings" be sure to select "Show Infrequently Used PIDs"
Here's the procedure I use with Dataviewer/Laptop.
I'm late for a meeting,,does that make sense?
Connect to the DSP
Connect to PCM with the "Lightening Bolt" to gather ALL availible PIDs
Select the Dashboard
Record.
Old 11-04-2009, 11:47 AM   #23 (permalink)
Chief's Avatar
So what do you guys do with this knock at 6k? just ignore it? try to add some fuel maybe? still getting some. right at 5800-6k on the dot every time.
Old 11-04-2009, 11:57 AM   #24 (permalink)
Chief's Avatar
Ill get a chart put up by the end of the day and show ya what i mean. This is on 18 psi 8:5 cr stock head, no meth 93 pump. with the gt35 i think my timmin is high teens area.
Old 11-04-2009, 05:11 PM   #25 (permalink)
Chief's Avatar
What you guys think... Now is this the wrong map pid to log??? im not running 33 psi?!?!? lol im running 18? my scan gauge says 18 and my boost gauge says 18? so maybe i loged the wrong "boost" pid?
so it would have been around 20 degrees if it wernt for some st knock, so i may try to take out 2 degrees up top and see if the knock disapears? if not im gonna guess its just the old 6k knock that everyone has with dsp. Dont really understand that? Other than that she pulls good, for 18 psi.
Old 11-04-2009, 05:12 PM   #26 (permalink)
Chief's Avatar
well that photo blows ass.... how the hell do i get one bigger lol
Old 11-04-2009, 05:24 PM   #27 (permalink)
Chief's Avatar
Better yet heres the log its self
RapidShare: 1-CLICK Web hosting - Easy Filehosting
Old 11-04-2009, 05:48 PM   #28 (permalink)
Chief's Avatar
So why the hick up at 5800-6k all the time with knock??? SEEms like everyone has that issue? is a dsp thing?
Old 11-04-2009, 08:39 PM   #29 (permalink)
duster360's Avatar
Most guys have a Knock issue right around 5200rpm. Your knock is quite a bit later in the RPMs than most guy's.
Depending on your A/F, removing 1 degree from 5k-6k will probably take care of most of your knock.
Old 11-04-2009, 08:44 PM   #30 (permalink)
Chief's Avatar
11.5-11.7 by that point... Should i add tad fuel or just lower timming -1? guess ethier or would work?
Page generated in 0.18821 seconds with 14 queries
