Quote: Originally Posted by
porksword
Looks like the same issue I just had. Your BARO looks low which in my case was a vacuum leak. It caused the A/F ratio to be so rich. If not I would test the MAP sensor next.
Your sensors aren't Scaled right if at all.
The BARO is VERY low as is the MAP pressure if its truely boosting 17psi.
A MAP of 22.6psi is usually only about 9psi. The jacked up(down) MAP is causing you to have too high of Timing(which you didn't bother to log,,Spark Adjust isn't it) and thats creating the knock.
Since the max P-ratio is nearly exactly what it should be, i think the MAP/TIP are incorrectly scaled and its not a individual sensor issue.
ps, The TIP sensor needs its OWN pressure line to the cold pipe. DO NOT Tee anything off it(BOV,fp reg, mbc, wga Ect),,,or at worse leave it open to the atmosphere.
pss, Next time log these PIDs:
What Parameters to Datalog
