5kr...pfft...come back and talk to me when you're knocking 9kr
lol I had gotten 9kr before, but several months ago,,,you could actually hear it,,not good
The higher Knock thresholds are working but I'm wondering if they aren't a little over board,,ei raise too much. Only 5Kr with +13:1 A/F, makes me think its possible. Maybe its fine, it just needs more testing.
I was looking at a guys Rage tune and Rage had just raised cyl #1 & #4 slightly above the Stage levels but left cylinders 2 & 3 stock.
I going to look for a PID that might ID which cylinder is knocking.
Loaded the new crom up, loaded the perf93 tune. Wanted to remove some fuel and it didnt load, now all it does is say that the original backup has to be restores. I click ok, and says its unable to load. tried 100 times and same notice. It even says the same thing when i plug it into the 12v converter.
Now i cant change anything.... damn im pissed
This happens some times with my Trinity too. Be sure to cycle the Predator On/Off and also the Car On/Off.
Usually i just have to reboot and it flashes fine.
Ive tried every single thing. Rebooted dsp, pulled fused, disconnected batt, wiggle wires and turn off every electronic device. Left eh batt disco for about 20 min, fuse aswell and nother.
I notice that when the DSP tell me to turn key off, then to turn it back on, the little red dot on dash stays lit up and DSP cant do anything...
The DSP recognizes the previous tune didnt work and asks to restore original tune. So when i agree and it tries to restore it it fails and all it does is reboot.
If i click ESC it allows me to go into regular diablo menu, so i tired loading the 93perf tune agian, original and nothing worked.
The SIM dot usualy only stays on for a couple of seconds. But whne the diablo asks you to turn key off then turn it on, the red DOT stays on for couple of seconds, then turns off for 1 sec and comes back on and never turns off, so im assuming that doesnt allow it to write the files.
