#1 (permalink) |
![]() Join Date: Apr 2005
Member Number: 27342
Hi I have had this issue for a long time with knock on my car. I now have a built motor and 50trim kit with 19-22lbs of boost and 100 meth and port fueler and predator. My ave air fuel ratio at wot is 11.3-11.9. I keep getting knock even in 5th gear flooring it and it starts when i get 2lbs of boost and it will ramp up to 3-4k of knock and lower a little as boost raises. Some time i get as much as 9.5knock just by flooring it for 3 seconds. Im thinking its a vibration noise, I have changed plugs, wires, coil, retorque exh bolts..... any ideas???... Ive also taken timing to -6 degress.....
| Sponsored Links | |
Advertisement |
#2 (permalink) |
![]() Join Date: Aug 2006
Member Number: 45182
Incorrect Knock sensor torque
Noisy forged pistons Hard trans mount high static compression port fueler doesn't mess with the map sesnor does it? Im thinking no. Datalog like a mofo and see exactly when its comming in.
This path assumes they knew what they were doing, which isn't necessarily the case"..........RB Racing TDS is the best choice for ALL your CMR Tuning. |
#3 (permalink) |
Noisy forged pistons Hard trans mount high static compression port fueler doesn't mess with the map sesnor does it? Im thinking no. Datalog like a mofo and see exactly when its comming in. well it does have a map clamp on it and i have 8.0 compression and no solid trans mount but i do have solid motor mounts, and torqued to specs |
#5 (permalink) |
duster whats the correct tq specs on the knock sensor? i thought you said last time it was 195lb? i have a 3/8 micro tq ratchet, 195 didnt feel right. too much.
Yes, 195 in-lb. be sure your wrench reads in-lb and not ft-lb. Otherwise 195ft-lb = 16.25 ft-lb interesting that the hemi's use the exact same sesnor but only torque it to 176in-lb. I heard rumors of the knock sensor being too sensitive and I have thought to experiment with different Torques. I think I'll test this lower torque setting.
This path assumes they knew what they were doing, which isn't necessarily the case"..........RB Racing TDS is the best choice for ALL your CMR Tuning. Last edited by duster360; 01-04-2009 at 07:39 AM. |
#6 (permalink) |
I'd ditch the clamp, recheck the Knock sesnor torque and retest. note: When i say "retest" I mean DATALOG and not just eyeball some stupid guage.
| Thread Tools | |
| Display Modes | |
