Old 10-08-2009, 09:18 PM   #1 (permalink)
sponsorSRT03's Avatar
Member Number: 58797
Default How much timing is too much timing
So i know a lil bit about ignition timing and when the pcm senses knock it retards the timing. So im running pump gas w 100% meth, ive ran meth for months and the pcm advanced timing on its own. I then did 3rd gear pulls and advanced timing from 3k-7k according to knock or lack there of. So my end result is 35.5-36* of timing at wot full boost. Zero knock showing. So is this too much timing. I mean im not knocking so i should b good rite? Im running 28psi w my 50trim.
sponsorSRT03 is offline   Reply With Quote
Old 10-08-2009, 11:59 PM   #2 (permalink)
cano's Avatar
Member Number: 2373
Susbcribed
12.706 @110 6/20.09 -- 12.827 @ 108.66 2/10/08
Stage 1, d44, DSP, 3" HP Racing turboback, Filled Motor Mounts, Spearco FMIC, Fuel Return Kit. M/T DR's on Rota Slipstreams
cano is offline   Reply With Quote
Old 10-09-2009, 12:04 AM   #3 (permalink)
lyncoo's Avatar
Member Number: 43166
Trader Rating: (92)
thats way to much good luck with that. 22-25 is ideal with big turbo, i ran 31* on 25 with no way of controling it, thank god nothing happen
AGP S256 FS
Old 10-09-2009, 12:06 AM   #4 (permalink)
Chief's Avatar
Member Number: 61336
I still to this day have no idea how you are running that much timming and not knocking. but ANYWAYS. do you know what advancing timming does??? Do you know if you have TOO much timming that its firing WAY BEFORE TDC and you can actually HURT your power? Your motor actually starts working against its self, more heat, more pressure on rods and pistons= fail. To tell you the truth i cant believe it has not given up yet. Most guys on big turbos run 15-20 pump 25 meth. I ran 31* 26 psi (gt35) and my rods did not like it. If i had DSP i would have been runnign 25, Yet i had ZERO knock (meth) does not mean your motor is gonna hold. More timming is not always better.
Built bottom end
strapped BC and CP
HTA 60
PTP when you fedex man gettin this block?
Chief is online now   Reply With Quote
Old 10-09-2009, 12:22 AM   #5 (permalink)
nutz's Avatar
Member Number: 41700
Trader Rating: (19)
wow 36* @ 28psi
make sure you are looking at the correct parameter
Old 10-09-2009, 12:23 AM   #6 (permalink)
lyncoo's Avatar
Trader Rating: (92)
Quote: Originally Posted by nutz View Post
wow 36* @ 28psi
he's looking at a time clock, it dings at 36seconds
Old 10-09-2009, 12:24 AM   #7 (permalink)
nutz's Avatar
Trader Rating: (19)
Old 10-09-2009, 12:25 AM   #8 (permalink)
Chief's Avatar
Just seems like alot of boost+timming w/o knock??? sounds fishy what are you lookin at to monitor knock?
Old 10-09-2009, 12:26 AM   #9 (permalink)
lyncoo's Avatar
Trader Rating: (92)
same thing doctors use, a th-----scope
Old 10-09-2009, 12:28 AM   #10 (permalink)
Chief's Avatar
Hopefully he does not say "well i don't hear any knock......"
Old 10-09-2009, 12:30 AM   #11 (permalink)
lyncoo's Avatar
Trader Rating: (92)
yeah i couldnt spell it
Old 10-09-2009, 12:41 AM   #12 (permalink)
nutz's Avatar
Trader Rating: (19)
Old 10-09-2009, 12:43 AM   #13 (permalink)
supermech21's Avatar
Member Number: 42969
Trader Rating: (73)
Lets make sure we understand a little about timing before we ask about it:
Spark advance, which is optimally timed to achieve best torque by producing peak cylinder pres at about 15* ATDC, increase octane requirements by half to three quartes of an octane number per degree of advance. Spark advance increases cylinder pressure and allows more time for detonation to occur.
So to be safe i would say 1* of timing for 1octane point.
Next, peak torque is = to peak VE(volumetric efficiency). Do you know when peak torque is achieved in your power band, that may make the next set of notes easier to compute.
The optimal amount of of timing advance varies inversly with VE because because denser mixtures burn faster and require less lead time to achieve the 15* peak. Therefore, engines need more advance at low-load, narrow throttle settings when VE is poor. VE is poor at idle, but engine engine speed is low, 8-20* of timing typically works well.
The on set of boost is increases the effective compression ratio, and combustion speeds up dramaticly, requiring less timing, and simultaneously increases the risk of detonation. Max timing at 1.0 bar boost is typically in the range of 23* at any engine speed, and 2.0 bar should be arround 21-22*.
All things being equal, bigger engines need more timing advance because it takes the flame(spark igniting fuel/air) longer to burn its way across the larger bore than the smaller one.
Does this make any sence?
Old 10-09-2009, 12:48 AM   #14 (permalink)
Trader Rating: (73)
This is the same guy that claims his car is at 468 when the conversion factor puts him arround 380/390...
Old 10-09-2009, 12:49 AM   #15 (permalink)
nutz's Avatar
Trader Rating: (19)
very nice
Page generated in 0.20548 seconds with 13 queries
