HOW TO: Mod Caliber 3bar sensor (P/N 5149056AA) - Page 11 - Dodge SRT Forum
 1Likes
post #151 of 159 (permalink) Old 10-01-2013, 10:26 PM Thread Starter
duster360's Avatar
Quoted: 136 Post(s)
Originally Posted by tz101 View Post
Please help me, ive got a srt 4 with stage 2 w/o toys, ive got a p4510365 map sensor in it right now. Im getting a cel code of p0108. If I do this MAP will the car run like it used to ???
As long as the MAP sensor is the actual problem and its not really a wiring issue, this sensor will work just fine as a replacement.
WWW.NEEDLESSTORQUE.COM
1025ccInj+ E85/GAS Base tunes =$385
E85+Gas Base tune Combo $150!!
Please EMAIL!!! dave at needlesstorque.com
www.facebook.com/needlesstorque
duster360 is offline
post #152 of 159 (permalink) Old 10-02-2013, 07:00 PM
Quoted: 0 Post(s)
problem solved frayed wire near cpu didnt use csrt map thanks !!
tz101 is offline
post #153 of 159 (permalink) Old 10-10-2013, 10:46 PM
Quoted: 0 Post(s)
just did this mod. very simple straight as a whistle. used a grinder wheel to modify the sensors. did nothing on the manifold. be careful with the harness when cutting the tape off. its pretty hard and you can cut a wire easily. great instructions.
xfranklyn is offline
post #154 of 159 (permalink) Old 08-28-2014, 11:48 AM
davidalindsey's Avatar
Quoted: 4 Post(s)
Garage
Okay so i am thinking about purchasing the Mopar Performance 3 Bar MAP Sensor/TIP SENSOR & Adapter Package from modernperformance. I am kinda confused on what is exactly needs to be done to the TIP sensor to make it fit on the white line. I am assuming the MAP sensor with the MPX adapter is just plug and play? Now the TIP portion i am not sure on what needs to be done...
I have a set of stage 2 injectors that were given to me and i have a DCR walbro 255 bypass modded fuel pump on the way. I wanted a re-scale done by a vendor here and thought I might as well get these in before I order a re-scale just for the injectors..
05 Neon SRT4
06 Infiniti G35x
98 Eclipse GST
davidalindsey is offline
post #155 of 159 (permalink) Old 08-28-2014, 01:36 PM
csmsach's Avatar
Quoted: 25 Post(s)
You need to essentially grind off the locking tab on the sensor and make it into the shape of a hose barb or you won't have a way to hook a hose into it. The sensor is designed to be keyed into the manifold then turned and lock into place. You have to eliminate that portion to use it as a tip sensor.
csmsach is offline
post #156 of 159 (permalink) Old 08-28-2014, 02:42 PM
Quoted: 4 Post(s)
Garage
ah that makes sense.
Thank you!
05 Neon SRT4
06 Infiniti G35x
98 Eclipse GST
post #157 of 159 (permalink) Old 12-31-2016, 05:19 PM
dave gregory's Avatar
Quoted: 9 Post(s)
FYI, good info
duster360 likes this.
1986 GLHS #329
2004 SRT4 Powered by DCR & Forward Motion
FM Stock Appearing Stage 5 Buildup (E1 Turbo, Factory cams/gears) Turn Key Ready
dave gregory is offline
post #158 of 159 (permalink) Old 01-05-2017, 06:47 AM
New Member
Quoted: 12 Post(s)
Duster360 I sent you a private message but looks like your inbox is full. I would like to get a tuning quote from you. Could you send me a PM?
srt4lemon is offline
post #159 of 159 (permalink) Old 01-09-2017, 08:22 AM Thread Starter
duster360's Avatar
Quoted: 136 Post(s)
READ my signature
User Tag List
Linear Mode Linear Mode
