HOW TO: Mod Caliber 3bar sensor (P/N 5149056AA) - Dodge SRT Forum
 1Likes
post #1 of 159 (permalink) Old 01-20-2010, 02:37 PM Thread Starter
duster360's Avatar
Quoted: 137 Post(s)
Here are the drawings showing you how to modify the Caliber 3bar MAP sensor 5149056AA to fit the NSRT-4 intake and to replace the TIP sensor.
For the slow kids, YOU NEED TO BUY TWO SENSORS FROM YOUR DEALER!!! ONE FOR THE MAP AND ONE FOR THE TIP
More details will follow but these will get most guys started
WWW.NEEDLESSTORQUE.COM
1025ccInj+ E85/GAS Base tunes =$385
E85+Gas Base tune Combo $150!!
Please EMAIL!!! dave at needlesstorque.com
www.facebook.com/needlesstorque
duster360 is offline
post #2 of 159 (permalink) Old 01-20-2010, 02:37 PM Thread Starter
duster360's Avatar
Quoted: 137 Post(s)
I got the modified MAP/TIP sensor put in tonight. It wasn't so bad.
MAP
First off you have to get the F'en thing to bolt down. PTP and Bid D are correct that a little extra whittling is needed to get the MAP to sit flat on the manifold.
Here's the culprit. There's a little flash on the intake and its hitting the MAP sensor slightly:
You can shave a bit off the sensor as suggested but I believe that modifing the manifold there's less risk of damaging the sensor. Your choice
If you decide NOT to buy or fab a sensor adaptor, you'll see that the new MAP is facing the wrong way and that makes the wiring almost too short. The tension on the wiring is unacceptably tight. DO NOT LEAVE THE WIRING SO TIGHT or eventually the MAP sensor connector will fail.
You can extend the wiring a couple inches but I saw that the MAP wiring on the harness was actually long enough but had some excess wrap up in the injector harness. So I slit the harness to free the excess MAP wiring and BINGO!! The harness reached the new MAP with no issues! The bare wiring shown is the extra length that was gained. The Zip tie is used as a strain relief.
Here's the finished product. All wrapped up like stock, BE SURE THE WIRING IS LOOSE and has a good 1" movement. Also the original screws will be too long. You need to find a shorter screw or do like I did. Since it was a Sunday afternoon and I was lazy, so I just used a little 1/4" spacer I had laying around :
TIP was much less involved. All I did was remove the TIP sensor bracket and drilled a hole for a sheet metal screw and wa'la. As long as the TIP is securely fastened in place it really doesn't matter if its actually bolted down:
Once evething is bolted/plugged in,,,Load your rescaled tune and CHECK IT OUT by looking at the BARO/TIP and the MAP with the KEY ON and the ENGINE OFF. If the 3bar sensors are used on a stock scale here whta you'll see:
If the scale is correct your MAP/TIP/BARO will match. The kPa will be between 95 to 101 depending on where you live.
Note: my BARO/TIP and MAP are off by about .6kPa--NOT a BIG deal. This is well within tolerance. 0.6kPa is only .09psi
post #3 of 159 (permalink) Old 01-20-2010, 03:08 PM
Gizmodo's Avatar
Quoted: 75 Post(s)
Holy huge images. Thanks Duster.
Gizmodo is offline
post #4 of 159 (permalink) Old 01-20-2010, 08:47 PM
Merderates da formz
NorthNJSRT4's Avatar
Quoted: 3 Post(s)
NorthNJSRT4 is offline
post #5 of 159 (permalink) Old 01-20-2010, 09:04 PM
16Boosted's Avatar
Quoted: 23 Post(s)
Looks good
AGP S256
UNTUNED
16Boosted is offline
post #6 of 159 (permalink) Old 01-21-2010, 07:18 PM
csmsach's Avatar
Quoted: 25 Post(s)
Outstanding!! Thanks for taking the time to make this.
csmsach is offline
post #7 of 159 (permalink) Old 01-22-2010, 08:41 AM
Big D's Blue 04's Avatar
Quoted: 0 Post(s)
Looks good, only thing I would change about the map sensor you need to take the front edge off because it hits the intake manifold and doesn't let the sensor sit flat. If you use the MPX adapter block this won't matter.
Big D's Blue 04 is offline
post #8 of 159 (permalink) Old 01-23-2010, 07:59 PM
Quoted: 0 Post(s)
Originally Posted by NorthNJSRT4 View Post
Been waiting on this one to upgrade. Annoyance = Awesome R&D.
Just like the R&D that we did so we could sell these to you guys.
Ding, this is a must when you install these on your stock manifold. You need to remove .050 to .080 off the sensor top, but don't take to much or you will run into the sensor electronics and ruin the sensor.
ptperformance is offline
post #9 of 159 (permalink) Old 02-25-2010, 04:43 PM
Merderates da formz
Quoted: 3 Post(s)
post #10 of 159 (permalink) Old 02-25-2010, 11:39 PM
Quoted: 0 Post(s)
You need to remove material off the sensor part itself. So the top of the "box" need to have .050 to .080 removed from it. This way it will clear the ridge on the intake manifold.
post #11 of 159 (permalink) Old 03-10-2010, 09:20 PM
SRT of the Month
radicalmark29's Avatar
Quoted: 0 Post(s)
Bump. Looking for a little more info on this. Anybody tried it? And on the tip sensor you have to cut it down to a half inch.. then shave it down so the diameter equals 5/16's or what?
And i think i can help with the pamn/pand dilemma..
radicalmark29 is offline
post #12 of 159 (permalink) Old 03-12-2010, 06:52 PM Thread Starter
duster360's Avatar
Quoted: 137 Post(s)
I had our machine shop mod the TIP today, and since the weather is a little nicer, i'll be putting these in this weekend. I'll add pretty pictures for everyone.
You don't have to shorten the TIP at all, just reduce its diameter to 5/16" and leave a little flange for a hose.
post #13 of 159 (permalink) Old 03-12-2010, 07:37 PM
Quoted: 0 Post(s)
Very nice!
(JPG )
2003 SXT
2005 SRT-4
titansrt4 is offline
post #14 of 159 (permalink) Old 03-14-2010, 10:47 AM
Mini Hemi's Avatar
Quoted: 0 Post(s)
Question
P/N for the TIP?
Mini Hemi is offline
post #15 of 159 (permalink) Old 03-14-2010, 11:55 AM
totaleclipse_05's Avatar
Quoted: 0 Post(s)
Originally Posted by Mini Hemi View Post
P/N for the TIP?
Same as the MAP.
totaleclipse_05 is offline
User Tag List
Linear Mode Linear Mode
