Old 01-01-2010, 12:28 PM   #1 (permalink)
Member Number: 24595
Default Hesitation/Stumble under light load. Help
So I had the car cmr tuned. 3076r setup w/750 cc's, return line setup at 58psi rising with boost, and of course 3 bars. Car runs fine any time its lower than 10 inches of vacuum, and runs fine under boost, but any time the vacuum is 11 or more, the car misfires. Anyone look at my file and see if anything is wrong? I was told it might be a scaling issue with the cmr tuner.
Deposit Files
2005 Stone White Srt-4
410Whp/385Wtq - Pump
staywide8 is offline   Reply With Quote
Old 01-01-2010, 07:36 PM   #2 (permalink)
ptperformance's Avatar
Member Number: 25514
Trader Rating: (586)
Deposit Files
What ignition parts do you have on the car?
Home of the DSP Tuned 657 WHP SRT4 Neon, 593 WHP SRT4 Caliber and the fastest stock turbo DSP tuned SRT4
DSP or Trinity
Old 01-02-2010, 06:33 AM   #3 (permalink)
Ngk 4306's, msd coil, and new stock wires
Old 01-03-2010, 07:00 PM   #4 (permalink)
Any help?
Old 01-04-2010, 10:06 AM   #5 (permalink)
Take off the MSD coil and put the stocker back on to see if the problem goes away.
Old 01-04-2010, 10:11 AM   #6 (permalink)
goats srt's Avatar
Member Number: 47689
Trader Rating: (23)
MSD coils are junk some people get real lucky with them but most don't
look in my for sale thread
click here
myfloridasrt
goats srt is online now   Reply With Quote
Old 01-04-2010, 10:13 AM   #7 (permalink)
Would that matter if I don't misfire at any other time? Especially under boost. Just asking again, not saying anyone's wrong/right.
Old 01-04-2010, 10:16 AM   #8 (permalink)
We have seen this a dozen times, pull the coil off the car and put the stock back on. It only seems to be a stuble that the MSD has issues with.
Old 01-04-2010, 10:19 AM   #9 (permalink)
I will try it and report back. Can you see if the tune is scaled correctly on the 3 bar ptp?
Old 01-04-2010, 10:23 AM   #10 (permalink)
I will need you to send me your tune file, send it to tunes@pt-performance.com.
This is the only way I can comfirm its correct, please make sure that you put some notes in with the email so I know what its in regards to.
Thanks.
Old 01-04-2010, 10:50 AM   #11 (permalink)
I posted it in the thread. I can't send email while at work. Will the post work?
Old 01-05-2010, 09:12 AM   #12 (permalink)
That is a datalog our your tune file? I really don't like opening up deposit files due to crap that can get attached but when I get home I will take a look at it.
Thanks.
Old 01-07-2010, 03:53 PM   #13 (permalink)
Ok. Update. I loaded 2 different maps that should fix my car, but it doesnt. It caues my vacuum to read 13.5 ish instead of the normal 18.5ish. Checked baro with ko/eo and it reads 10.5. I checked both part numbers on the sensor and there both 3 bar sensors. With the maps though, my car does run and idle better.
Old 01-07-2010, 08:40 PM   #14 (permalink)
Help!!
Old 01-07-2010, 10:19 PM   #15 (permalink)
duster360's Avatar
Member Number: 45182
10.5psi Baro with KO/ EO just means the MAP/TIP sensor scales are jacked up in both maps. If you're actually in Dublin Ohio, your BARO and MAP at KE/EO should be right around 14.73psi as of this posting.
