Old 07-02-2009, 07:36 PM   #1 (permalink)
Member Number: 60287
Default Heres my first log.
Hows this look? Any advice? I am running a stage 3 setup with agp returnline, 3inch tbe, bfmic. Its about 90 degrees outside and 100% humidity.
RapidShare: Easy Filehosting
jukens is offline   Reply With Quote
Old 07-02-2009, 08:26 PM   #2 (permalink)
Kason23's Avatar
Member Number: 34502
Trader Rating: (20)
What kinda gas and is there METH??? Are you on PCM control? looks pretty good. I would try to up the timing a little starting at 16ish is low imo. Try 20 in that range and go up from there.
Tuned By TDSAaron!!
Old 07-02-2009, 08:28 PM   #3 (permalink)
AGP WGA off PCM control, running 93 octane no meth. I have just been pulling fuel to get the afr's where I need them, havent messed with timing yet.
Old 07-02-2009, 08:32 PM   #4 (permalink)
Kason23's Avatar
Trader Rating: (20)
Just seen you hit 27psi on pump gas?!?! But seems you are getting away with it cause your timing is so low. Whats the AFR's. I believe once you try to up the timing your going to knock something fierce. that seems like alot on a S3R car on pump with no meth. But I may be wrong....
Old 07-03-2009, 02:02 PM   #5 (permalink)
Member Number: 43905
bump...
98 R/T 4door
toomey200 is offline   Reply With Quote
Old 07-03-2009, 02:48 PM   #6 (permalink)
Is the AFR reading from the DSport correct? On my wideband i never hit 12afr im in the 11s all the way to redline but on the log its showing staying in 12s at wot.
Old 07-03-2009, 02:55 PM   #7 (permalink)
Kason23's Avatar
Trader Rating: (20)
NO thats a commanded AFR. Its what the PCm is trying to hit. Always go by your wideband
Old 07-03-2009, 06:12 PM   #8 (permalink)
Member Number: 50647
i dont want to make another post so here my log
21 psi 91 oct pull on a 50t 3th and 4th gear
RapidShare: 1-CLICK Web hosting - Easy Filehosting
i had 1 degree of knock but it was a 28 degree celcius and 95% humidity day
speedup is offline   Reply With Quote
Old 07-03-2009, 06:30 PM   #9 (permalink)
Kason23's Avatar
Trader Rating: (20)
Can you log ST and LT knock. That would help more then a Total imo. What boost controller do you use?
Old 07-03-2009, 11:47 PM   #10 (permalink)
im new to logging lol
i used a greddy proffec b spec 2
Old 07-04-2009, 12:39 PM   #11 (permalink)
Member Number: 69818
I also didn't want to make another post. Here's my first two pulls
Mods are 3in TBE(no cat), AEM CAI, AEM wide band, race motor and trans mounts. Its a 2005 and i loaded the modify stock tune. I don't have access to 93 oct so i didn't want to load that tune. RapidShare: 1-CLICK Web hosting - Easy Filehosting
teribble1 is offline   Reply With Quote
Page generated in 0.16312 seconds with 13 queries
