Old 07-03-2009, 10:12 PM   #1 (permalink)
Member Number: 37190
Default DSP, Stage 2 injectors, walbro etc. ?'s
Ok, I am really green when it comes to tuning so be easy on me. I believe I am ready for the DSP. Mods so far are St. 1 pcm (which I will swap out for my St. 0), AGP WGA, AGP fmic, Thermal R & D tbe. I do have a wideband and scangauge as well. Stock turbo, btw.
This is my question. Would it benefit me to purchase the stage 2 injectors and a walbro along with the DSP? Or is that not necessary? I have an '05 SRT, so I already have the St. 1 injectors. I can get new st. 2 injectors and the walbro from a local guy for like $200.
Also, would the 93 octane tune be sufficient with the boost that I am running now (17-18 psi) and the stage ones?
Thanks guys!!
Brian
SpecV is offline   Reply With Quote
Old 07-03-2009, 10:29 PM   #2 (permalink)
turbo666's Avatar
Member Number: 25206
Trader Rating: (31)
I recommend the stg 2's and a rescale at the very least so you will have plenty of fuel and keep injector duty cycle low. You don't NEED a Walbro, but if your stocker is high mileage then it won't hurt to replace it.
Nigel
04 Srt-4-AGP Borg Warner S360-RS, E85, and MUCH MORE coming soon...
7.493@99.56<-- granny shifting on 30r with 93/meth <--OLD SETUP!
FIRST TO MAKE BIG TURBO PCM BOOST CONTROL WORK ON DIABLO!
For custom tuning, installs, and transmission rebuilds PM me!
www.trudynosports.com
Old 07-03-2009, 10:35 PM   #3 (permalink)
Cool thanks, my car has less than 36K on it so I'd say I'm good but may go ahead and get the cheap insurance.
I guess I'll order my DSP Monday then.
Old 07-03-2009, 10:39 PM   #4 (permalink)
turbo666's Avatar
Trader Rating: (31)
Go for it! DSP is awesome. I hate tuning piggybacks now that I have done DS tuning. Just wish it could tune line instead of having to reflash.
Old 07-04-2009, 09:17 AM   #5 (permalink)
rrmike1's Avatar
Member Number: 55729
Throw in a fuel pump re-wire while you're at it. It's cheap, easy to install and allows your pump to get the right amount of voltage.
Mopar S2 no toys, FBM pnp'd turbo/mani., Rage 55mm T/B, AGP WGA, AGP CAI, MPx 3" O2, Maxxfab 3" DP, Mopar Exhaust, AEM UEGO, SprayItRacing BOV, Crane 8.5mm wires, Champion RE10pmc5's, Stant 180 thermo, Prothane race MM inserts, Autometer 30/30, Tein H's, Proparts dual-gauge pillar, Fuel pump re-wire, NOS Sniper kit
rrmike1 is offline   Reply With Quote
Old 07-04-2009, 10:24 AM   #6 (permalink)
Yea, thought about that too. So can I rescale the stage 2 injectors using the handheld? Don't worry guys I will not be doing this alone, I will get help from a fellow SRT owner who knows a great deal more about this crap than I do. Thanks for the help!!
Old 07-04-2009, 04:00 PM   #7 (permalink)
turbo666's Avatar
Trader Rating: (31)
No. The injectors can only be rescaled by a person/place with the CMR software.
Old 07-04-2009, 04:08 PM   #8 (permalink)
Member Number: 71225
hey i got 4 brand new mopar stg2 injectors u can check it out in the florida for sale section
AnsareStg0 is offline   Reply With Quote
Old 07-04-2009, 04:50 PM   #9 (permalink)
Hey I checked your thread. Thanks for the offer but I am getting 4 new Stage 2 injectors and a brand new Walbro for $180, locally.
He's been trying to get rid of them for a while now.
Thanks for the offer though.
I've decided to order the DSP Monday and then the injectors and fuel pump later next week since I'm getting such a good deal on them.
Then as MC Hammer once said, "Hammer time!!".
Old 07-04-2009, 05:05 PM   #10 (permalink)
Gottcha. Is it necessary to get them rescaled? Or can I just drop them in and make adjustments with the DSP?
Old 07-05-2009, 01:40 AM   #11 (permalink)
needs to be rescaled
Old 07-05-2009, 04:53 AM   #12 (permalink)
Adionik's Avatar
Member Number: 51197
Trader Rating: (25)
You have to pay (Unless you get it free) a CMR dealer to rescale. Go with Nigel/Aaron. Ridiculous turn around speeds on rescales.
Take note though that you will have to pull a very good amount of fuel with stage 2's and a Walbro, that's my exact fuel setup and I had to pull a lotttttttt
or 16 whatev
Quote: Originally Posted by nutz View Post
stock turbo and 750's you may run outta fuel try some 1600's
Adionik is online now   Reply With Quote
Old 07-05-2009, 10:48 AM   #13 (permalink)
Sounds good thanks!! What kind of numbers are you making with this set up?
What mods do you have?
Old 07-05-2009, 11:51 AM   #14 (permalink)
Once again, forgive me for my lack of knowledge. I am trying to learn. What is involved in rescaling injectors? I will do a search if need be, but I am using mobile right now. Also, what is the cost?
Old 07-05-2009, 02:11 PM   #15 (permalink)
Louisvilleguy's Avatar
Member Number: 17118
Nigel (turbo666) could do it, and PTP is doing them as well. A simple rescale shouldn't be more than $40 or so. When they do that I believe all that they are doing is adjusting the injector duty cycle to control the amount of fuel that is going into the cylinders at idle and various RPM. Your PCM now is setup to operate at a particular IDC with the stock size injectors in mind. Operating at these same percentages with a larger injector leads to injecting more fuel than with the previously smaller injectors.
Even with the rescale I think you will need to make adjustments with your handheld still. But you'll be in the ballpark and it should be easily managable.
04 SRT-4
- FP Green model
- 344whp/375wtq (AGP flash 93 octane)
Louisvilleguy is offline   Reply With Quote
Page generated in 0.20530 seconds with 13 queries
