Diablosport problem! help!! - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
Old 01-14-2013, 10:09 AM   #1 (permalink)
matman2492's Avatar
Member Number: 91147
Default Diablosport problem! help!!
so bought my diablosport predator and loaded the performance preloaded tune. when i started driving it the turbo was fluttering really bad so i dialed the boost back as far as it would go, any solutions to this? i can drive the car without it happening its just annoying when i wanna accelerate a little bit i get the flutter under 3.5k rpm. when i wanna drive her hard she doesnt flutter at all tho because the rpms are higher. any solutions or anyone else experience this?
matman2492 is offline   Reply With Quote
Old 01-14-2013, 10:20 AM   #2 (permalink)
Ratman's Avatar
Member Number: 83208
I had the same issue shortly after I uploaded the 93 tune. I fouled out one of my plugs. I put in some NGK LZTR6AIX-13 and problem gone. A lot of guys run these once you start increasing boost. Hope this helps.
Ratman Racing
Ratman is offline   Reply With Quote
Old 01-14-2013, 12:10 PM   #3 (permalink)
silver_ek's Avatar
Member Number: 60962
so youre getting flutter when not in boost?
"Duster360 knows his $hit"
silver_ek is offline   Reply With Quote
Old 01-14-2013, 12:14 PM   #4 (permalink)
Fresh Meat Moderator
tunerlover3's Avatar
Member Number: 76568
What mods do you have?
Have you done a proper boost leak test?
Diablo CMR tuner ~Dan~
310HP 436TQ
XXXHP XXXTQ
Old 01-15-2013, 08:22 AM   #5 (permalink)
matman2492's Avatar
when im at low rpms and push down the pedal too far to start building boost the car with flutter, basically the rpms are too low to let the extra boost build so it gets thrown back out of the turbo
i have a cai, bfmic, stage 1 injectors not much really. i took my agp wastegate off to put the stock one back on becuz i heard it was better for the 93 tune
Old 01-15-2013, 08:44 AM   #6 (permalink)
benspilk09's Avatar
Member Number: 88421
Flooring it at low rpm will always make it flutter.
Even with the stock WGA
If you just had the AGP WGA on then try resetting the computer by unhooking the battery, the ECM may need to to re-learn with the stock one.
benspilk09 is offline   Reply With Quote
Old 01-15-2013, 11:28 AM   #7 (permalink)
Crazyced's Avatar
Member Number: 56385
As previously said, once you are back on stock WGA on solenoid, reset the PCM by unplugging the battery for a couple of minutes then flash the 93 tune back on. The try not to go WOT much before 3000rpm.
Crazyced is offline   Reply With Quote
Old 01-24-2013, 10:13 AM   #8 (permalink)
matman2492's Avatar
so its will always flutter after i tune it? it didnt before the tune so i feel like it shouldnt after, not like i have a bigger turbo on. Ill try and reset the car again but i already did to load the tune. if i put the agp wastegate back on is that going to stop the flutter becuz the wga is controlling the boost then not the computer?
Old 01-24-2013, 11:02 AM   #9 (permalink)
SRT of the Month
underSRTarmor's Avatar
Member Number: 32888
its compresser surge....
it can destroy the turbo and engine don't go wot before 3k on stock turbo...
Old 01-24-2013, 11:14 AM   #10 (permalink)
Crazyced's Avatar
it can destroy the turbo and engin. got go wot before 3k on stock turbo...
He claims he didn't have that before the tune, which is odd.
Old 01-24-2013, 11:27 AM   #11 (permalink)
SRT of the Month
Check plugs.
If you run the 4306 they should be changed every other oil change. They cheap and wear out kinda quick.
Sent from
Old 01-24-2013, 07:08 PM   #12 (permalink)
Putting the AGP on will make the fluttering worse.
Do a boost leak test and make sure you have no vacuum/boost leaks first.
310HP 436TQ
XXXHP XXXTQ
Old 01-25-2013, 09:21 AM   #13 (permalink)
DiabloMike's Avatar
Member Number: 73161
does not sound like a tune related issue....
DiabloMike is offline   Reply With Quote
