Old 07-04-2009, 04:12 PM   #1 (permalink)
perfectcircle's Avatar
Member Number: 38378
Default Datalog of my track time lastnight
Alright this is the first time I've ever ran the Diablo at the track so I decided i would datalog the run. And from the datalog looks like i'm hitting around 23 psi.. oh yea and street tires...
R/T .272
60' 2.245
1/8 8.696
mph 87.83
1/4 13.111
mph 113.83 <---seems really low... but I did bang of the rev limiter in 2nd
RapidShare: 1-CLICK Web hosting - Easy Filehosting
AGP 3147
Diablo
TDSAaron Tuned!
perfectcircle is offline   Reply With Quote
Old 07-04-2009, 07:36 PM   #2 (permalink)
Kason23's Avatar
Member Number: 34502
Trader Rating: (20)
I was there... If you would of got a clean run in I know you would of hit 115mph. But that low timing of yours is what i'm concerened with
Tuned By TDSAaron!!
My Goal: 100+Mph in the 1/8
Old 07-04-2009, 08:23 PM   #3 (permalink)
Xx_R/T_xX's Avatar
Member Number: 18749
i ran the best of 12.5@118 on my d55 with only 22* of timing and 4kr of knock.and that was on street tires(knock has been fixed,timing as been increased)
so like kason said,ur timing must be really low and you arent getting the full powe that turbo makes
BIG TURBO!
Old 07-04-2009, 09:03 PM   #4 (permalink)
I know man... we've got to get mine up to par! Since I only really got one run in, I think the time was decent just disappointed with that trap. You need to come by Monday night and we'll boost leak and mess with my timing
Old 07-04-2009, 09:42 PM   #5 (permalink)
Kason23's Avatar
Trader Rating: (20)
Sounds good man and R/t his timing was 17* at some points lol so yea its super low!
Old 07-04-2009, 11:43 PM   #6 (permalink)
Kason23's Avatar
Trader Rating: (20)
Damnit Jeremy you boost holds fine.... How about you let me borrow your contoller for a run and us datalog it to see if mines shot
Old 07-05-2009, 04:04 AM   #7 (permalink)
No problem, not like its hard to swap out
Old 07-05-2009, 04:12 AM   #8 (permalink)
Member Number: 7593
R/T .272
60' 2.245
1/8 8.696
mph 87.83
1/4 13.111
Holy crap dude!! What do your AFR's look like?? you have a TON of KR going on in there. What octane fuel are you using?
I say "TON" because its pretty much constant once it sets in.
Charge temps look ok, so.. that's not an issue.
I do see a COT issue (cat over temp) pretty much a standard thing on these cars, which CAN be disabled.. but, requires a CMR to do so.
That car,.. should be MUCH faster! Hell dude,.. my stock turbo'd car would give you more than a fight (off the nitrous)
I'm not trying to shoot you down,.. the car has the potential.. you just need to get everything ironed out.
In my opinion, that thing should be in the 117 mph range at LEAST on pump.
Stage 1 ECM (NOT stock), Diablosport Predator, 3 bar map and tip, Interceptor Scangauge, AEM wideband, 750's (no return-line), MPX BFMIC, Walbro 255, DCR top end modifier, AGP WGA, 3 in O2 housing, QTP 3in downpipe with E-cutout stock catback, Nitrous Oxide Systems 65 HP shot, motor mount inserts.
Best MPH to date on the bottle,119.04 --- Off the bottle 113.55. --- best ET 12.44. on borrowed DR's. Stock turbo, stock Mani.
Nosfurato is offline   Reply With Quote
Old 07-05-2009, 01:33 PM   #9 (permalink)
Hmmm... well the afr's are in the low 11's to mid 11's, I dont see a "TON" of knock but it is getting almost 3 counts.. I dunno man.. as far as the COT goes I know Aaron turned it off so that shouldn't be an issue. I agree though car should be trapping close to 120's..
Old 07-05-2009, 01:36 PM   #10 (permalink)
Kason23's Avatar
Trader Rating: (20)
Im still down to say drop your boost to 20 and see if you can get 22-23* out of it with no knock. hell you dyno'd 380whp on just 20lbs lol. Thats still alot of power imo
Old 07-05-2009, 04:15 PM   #11 (permalink)
We can try it man, I'm down for about anything.. 377 whp to be exact but that was with the SAFC so you know the timing was wayyyy up there
Page generated in 0.20402 seconds with 13 queries
