Old 10-31-2009, 04:32 PM   #1 (permalink)
Member Number: 73095
Default D Sport and catless code?
many ppl have told me if your running a dsp on stock computer it wont throw a cat code when you go open downpipe? just wondering if its true or if you still have to do the non fouler mod
micro12 is offline   Reply With Quote
Old 11-01-2009, 06:53 AM   #2 (permalink)
The_Red_Barron's Avatar
Member Number: 64362
The DSP can be used to prevent the CEL from going off from having a straight pipe, but it doesn't disable the code all together like the staged PCMs. It sets them to "not ready" and therefore, at least in my case and others that I've seen, won't pass inspection unless you set it back to stock. If your mods are mostly bolt on and you can run with a stock tune, make sure your straight pipe has a bung that will prevent the computer from setting off the CEL, set the car back to stock, and then drive it for like 15 miles and you should be good to go. I learned this the hard way driving over 100 miles trying to get the damn thing to be "ready" lol
Quote: Originally Posted by neonjr View Post
Comparing anything to a Viper is like comparing Chuck Norris to Richard Simmons, both work out a lot but one kicks ass and the other is
2005 ACR SRT-4 (mmmmmm...)
1999 Nissan Sentra SE Limited (sold, thank god!)
2002 Honda Civic EX Coupe (totalled )
1987 Dodge Ram Charger (sold)
The_Red_Barron is offline   Reply With Quote
Old 11-02-2009, 10:55 AM   #3 (permalink)
ptperformance's Avatar
Member Number: 25514
Trader Rating: (567)
But you still want to get the COT shut off, let me know if you wan to get this done, see e-mail below.
Thanks.
Home of the DSP Tuned 657 WHP SRT4 Neon, 593 WHP SRT4 Caliber and the fastest stock turbo DSP tuned SRT4
DSP or Trinity
Old 11-02-2009, 04:12 PM   #4 (permalink)
thoedsrt4's Avatar
Member Number: 51089
what happends if u take the cot off?
thoedsrt4 is offline   Reply With Quote
Old 11-03-2009, 07:45 AM   #5 (permalink)
Gizmodo's Avatar
Member Number: 22931
You could potentially destroy your cat. However, the more likely scenario is you won't have your AFRs tank in 4th gear when doing a pull through the gears. The problem is our cars don't actually monitor EGTs, it is all based off of tables in the PCM, so various mods can significantly affect actual vs. calculated EGTs. The only true way to know would be to install an EGT probe and monitor. I have one installed, just too lazy to actually do some monitoring and I don't have access to the CMR software to see how close actual vs calculated is. I'm sure someone on here has done that though.
Gizmodo is offline   Reply With Quote
Page generated in 0.12676 seconds with 13 queries
