Old 10-26-2009, 04:11 PM   #1 (permalink)
93stang434's Avatar
Member Number: 49690
Default Crom updates and custom tunes
I was tuned using crom 9r12 is it possible that using a newer crom like 9r17 could change the tune or the way it makes the car behave.
E1 w/ported 3" anti-surge cover,LCR fully ported ext.gated exh mani,3" o2 housing,3"SEE,N2MB boost box,
S2 injectors,diablosport predator,coolingmist w/m
255 pump,rewire,bottleneck mod,returnline
MPx bfmic,55 t-body,180 t-stat,DCR oil restrictor
Best E.T 12.12 Best MPH 118.71 DR's,full weight no n2o
Tuned by Nemo@Rage-Tek & myself http://www.srtforums.com/forums/f146...charts-480643/
93stang434 is online now   Reply With Quote
Old 10-26-2009, 04:29 PM   #2 (permalink)
ptperformance's Avatar
Member Number: 25514
Trader Rating: (567)
There could be some changes that will not "stay" if you switch over to the newer CROM file. If Nemo tuned it, then you should have a saved file somwhere and that file should work on any of the CROM files... should being the key word.
Home of the DSP Tuned 657 WHP SRT4 Neon, 593 WHP SRT4 Caliber and the fastest stock turbo DSP tuned SRT4
DSP or Trinity
Old 10-26-2009, 04:36 PM   #3 (permalink)
93stang434's Avatar
I hear ya on the should part....i'm going back to 9r12 to see if it behaves or not lol.Thanks for the response.
Old 10-26-2009, 04:40 PM   #4 (permalink)
Anytime.
Old 10-26-2009, 04:49 PM   #5 (permalink)
93stang434's Avatar
Well its not going to happen because they are no longer on Diablo's site only 9r18 is available.
Old 10-26-2009, 05:03 PM   #6 (permalink)
93stang434's Avatar
We found them..... 9r12 it is
Old 10-26-2009, 08:44 PM   #7 (permalink)
duster360's Avatar
Member Number: 45182
If you upload your original 'custom' tune from Rage and NOT your 'Last tune written' to the Predator, I don't see why the crom rev maters.
Old 10-27-2009, 05:12 PM   #8 (permalink)
93stang434's Avatar
I wouldn't think it would matter either i'm just trying to narrow down the possibilities.
Old 10-27-2009, 05:22 PM   #9 (permalink)
Kason23's Avatar
Member Number: 34502
Trader Rating: (20)
Makes me wonder if my knock threshold was upped when Aaron did my tune. And If I could flash mine back to stock put in the new Crom. (im on 16 right now) and flash my custom back in.. Would that up the sensitivity?
Tuned By TDSAaron!!
My Goal: 100+Mph in the 1/8
Old 10-27-2009, 05:47 PM   #10 (permalink)
93stang434's Avatar
I put 9r16 on about a month ago and it seems ever since when i power shift i'm getting a lot of knock during the shift....it goes right away but it takes long enough that i can feel the car pick up as the timing comes back, so i'm just trying to figure that out.The custom tune should be written over the tune thats in the pcm you running unless the 93 octane tune was used as a base,in that case your knock sensitivity could change with the updated crom but i don't know for sure.
Old 10-27-2009, 05:55 PM   #11 (permalink)
duster360's Avatar
I'm pretty sure a different CROM in no way effects a custom tune.
Old 10-27-2009, 08:27 PM   #12 (permalink)
Xx_R/T_xX's Avatar
Member Number: 18749
im on crom 16 now,wanting to swtich to 18,but not sure if the custom tune will behave diffrently on the new crom
BIG TURBO!
Old 10-27-2009, 09:09 PM   #13 (permalink)
cano's Avatar
Member Number: 2373
Well I should shoot myself cause my car was running better than ever on 16. I decided to upgrade to 18 and I did, needless to say my car sucks now. I put the tune back on and it ran like sh@t. I tried every tune I have and same thing. John from PTP sent me 2 tunes and same thing. I had a event that I wanted to run on last sat so I ended up putting it back to stock and using my dTec for the event, didn't do too good (13.1) but at least it ran all night. But it did proof to me that either the 18 crom has issues.
The issue is, it pulls hard as hell until i go WOT, then it simply falls on it;s face
Comments welcomed
12.706 @110 6/20.09 -- 12.827 @ 108.66 2/10/08
Stage 1, d44, DSP, 3" HP Racing turboback, Filled Motor Mounts, Spearco FMIC, Fuel Return Kit. M/T DR's on Rota Slipstreams
cano is offline   Reply With Quote
Old 10-27-2009, 09:25 PM   #14 (permalink)
93stang434's Avatar
Comments welcomed
put 16 back on it and see....i'm going to the track tomorrow to see if i still have an issue.
Old 10-27-2009, 09:38 PM   #15 (permalink)
duster360's Avatar
it did proof to me that either the 18 crom has issues. Comments welcomed
The only real proof would be to revert to the 16 crom and it magically fixes your issues.
Have you done this?
Have you fixed it in another way?
There have been documented issues from CMR tuners that some custom tunes would not flash all(or any) of their changes to the PCM long before 18 came out.
Of course if no changes were being applied to the PCM from the custom tune, your car would "seem" to run like shit.
I would be ABSOLUTLEY sure all of you running year old croms, UPDATE your DS Downloader to the newest version I'm using 2.2.0.1
Page generated in 0.15494 seconds with 13 queries
