Old 10-31-2009, 04:30 PM   #1 (permalink)
Member Number: 75447
Default any input would help
i installed the 93 tune and i was running lean, and knocking between 5-6k. I added some fuel and my afr's are fine now...then i took -2 deg timing from the 5-6k range but im still at a 6 on ST knock
Aimois is offline   Reply With Quote
Old 11-02-2009, 08:52 AM   #2 (permalink)
Gizmodo's Avatar
Member Number: 22931
What type of fuel are you using? Do you have a catch can? It is possible the gas stations in your area have already switched to a winter blend as well.
Gizmodo is online now   Reply With Quote
Old 11-02-2009, 10:36 AM   #3 (permalink)
ptperformance's Avatar
Member Number: 25514
Trader Rating: (567)
Add more fuel and see if it goes away. What CROM file are you on? If you don't have the latest 18r file then you are not getting the knock sensor adjustments, which will help rid some of the ST knock. I would try adding more fuel and see where that takes you.
Home of the DSP Tuned 657 WHP SRT4 Neon, 593 WHP SRT4 Caliber and the fastest stock turbo DSP tuned SRT4
DSP or Trinity
Old 11-02-2009, 10:40 AM   #4 (permalink)
duster360's Avatar
Member Number: 45182
Look here for answers:
Newb Tuning lesson part 1
duster360 is online now   Reply With Quote
Page generated in 0.11513 seconds with 13 queries
