Old 09-19-2009, 10:12 AM   #1 (permalink)
Member Number: 27268
Default Adjusting Parameters on Stage3
I now have my DSP and have made a few 3rd gear pulls logging the suggested parameters. I am running a ported head and would like to pull some timing from the HOM mode and tweak the boost:
When I adjust fuel / boost / timing, does it effect all DAB (dial a boost) settings and HOM, just the non-HOM mode or what?
Z
'04 Black SRT-4 -- Stage 3
'02 300M Special SOLD
'09 Challenger R/T - Commuting City 23MPG
ZedOne is offline   Reply With Quote
Old 09-19-2009, 12:45 PM   #2 (permalink)
93stang434's Avatar
Member Number: 49690
Z
From what i have heard or seen from guys with the cmr software they have no clue how HOM does what it does or how to change it.Changing the timing with the hand held doesn't touch HOM timing nor does a custom tune from what i have read.Lowering the boost with the hand held won't change dab 0 (spring pressure) but in the other setting it might... give it try you can always change it back.
E1 w/ported 3" anti-surge cover,PTP,LCR fully ported ext.gated exh mani,3" o2 housing,3"SEE,N2MB boost box,
S2 injectors,diablosport predator,coolingmist w/m
255 pump,rewire,bottleneck mod,returnline
MPx bfmic,55 t-body,180 t-stat,DCR oil restrictor
Best E.T 12.12 Best MPH 118.71 DR's,full weight no n2o
Tuned by Nemo@Rage-Tek & myself http://www.srtforums.com/forums/f146...charts-480643/
93stang434 is offline   Reply With Quote
Old 09-19-2009, 12:51 PM   #3 (permalink)
Philth's Avatar
Member Number: 46647
Trader Rating: (30)
All HOM is, is a multiplier. So if you globally reduce timing off HOM, the same will happen on HOM.
Old 09-19-2009, 01:44 PM   #4 (permalink)
93stang434's Avatar
I don't think it works that way,i would say it works off of MBT if anything. HOM doesn't work with my custom tune and Nemo said it wouldn't when he tuned it and also john from ptp said if he tried to change it it doesn't work.I don't know for sure myself how it works (don't have cmr or sct prp)and yes the general consensus is its a multiplier but as far as i have seen on my car pre tune HOM did what it did regardless of what i did with the timing.
Old 09-19-2009, 09:49 PM   #5 (permalink)
duster360's Avatar
Member Number: 45182
Yes, thats the consensus but I only heard it from 1 source albeit a very reliable one Nemiro. I'm looking a the S3 calibration file right now and I can't see anything that equates to a HOM, so it beats me??? But since Neil's been reprogramming Chrysler PCMs while most kids here were still in grade school,(i bought a custom SBEC from him in '95) i give him the benefit of the doubt until proven otherwise.
duster360 is online now   Reply With Quote
Old 09-19-2009, 11:54 PM   #6 (permalink)
Philth's Avatar
Trader Rating: (30)
Thats where I got my info from as well. MindMelt told me this also.
Old 09-20-2009, 01:54 AM   #7 (permalink)
93stang434's Avatar
The fact (or not ) thats its a multiplier doesn't change the fact that changing base timing has no effect on HOM, and since you can do whatever you want with the timing with the hand held it seems inconsequential.
Old 09-20-2009, 08:09 AM   #8 (permalink)
Thanks for the response. I will start adding a little boost/fuel and log the results.
