Old 10-22-2009, 09:37 AM   #1 (permalink)
Member Number: 39822
Default 60-1 3rd gear datalog...
For some reason I just started picking up knock when I have not been. This datalog is with the 4306 plugs but I canged them back out and put the 2 step colder Iridium plugs back in at a .028 gap but it still did not help. I also found and fixed 3 boost leaks and it still did not help. I am running about 20psi with the af's in the hight 10's to mid 11's at redline on 93oct pump gas. I just don't see why it is knocking, anybody see anything wrong that might help me fix this?
Deposit Files
Mods Are:
ptp 3 bar map/tip sensors
agp cold air intake
55mm throttle body
ngk 2 step colder plugs
rc750's
255 pump
3" exhaust
bb 60-1 turbo upgrade
bfmic with all piping
diablosport predator
I'm sure there is more I just cant think right now.
2004 SRT-4 Precision 60-1 @ 22psi
Diablosport Predator Tuned by TDSAaron
1/4th Mile Best On Street Tires
12.4 @ 121mph 2.2 60ft
oleBLUE is offline   Reply With Quote
Old 10-22-2009, 01:05 PM   #2 (permalink)
duster360's Avatar
Member Number: 45182
Just a few thoughts:
1) It could just be the gas you're using. Many stations are switching to a crap winter blend around here. Run this tank through and switch brands to see what happens. Be sure to clear the LT Knock before testing.
2) Your most prominent knock is at ~5100rpm, where, imo, false knock pops up. Be sure your Knock sensor is properly torqued to no more than 190in-lbs.
3) If this is a new tune, be sure TDS raised your knock thresholds. As far as I know, they usually do. won't hurt to double check.
4) Just a general observation: I've notice since last winter, most guys have a reduction in Knock as temps got warmer. Having a colder ACT but the same Boost psi does increase the charge density and likelyhood of knock, if the timing isn't properly reduced to match. I suspect we'll see more threads from guy's complaining about a sudden rise in knock.
Old 10-22-2009, 01:48 PM   #3 (permalink)
Well, I already did the fuel switch and it did not help. TDSAaron has already raised my knock thresholds also. You are right and kason23 told me the same thing it does seem to want to knock more in the colder air. Does everything else look pretty good to you?
What do you mean by clearing the LT knock? Just reset the computer or something?
Old 10-22-2009, 05:36 PM   #4 (permalink)
ttt.....
Old 10-23-2009, 02:52 PM   #5 (permalink)
Member Number: 72904
where exactly is the knock 1 sensor located?
drewharvey101 is offline   Reply With Quote
Old 10-23-2009, 04:09 PM   #6 (permalink)
KBzPTGT's Avatar
Member Number: 112
Trader Rating: (10)
Will item #4 occur with PCM controlled boost?
KBzPTGT is offline   Reply With Quote
Old 10-23-2009, 04:42 PM   #7 (permalink)
x2......
Old 10-23-2009, 05:37 PM   #8 (permalink)
Kason23's Avatar
Member Number: 34502
Trader Rating: (20)
I believe the knock sensor in underneath the intake manifold right?!?!
And you reset LT knock by taking the negative off the battery or pull the 20 amp fuse underneath the hood.
Tuned By TDSAaron!!
My Goal: 100+Mph in the 1/8
Old 10-23-2009, 05:56 PM   #9 (permalink)
Kason23's Avatar
Trader Rating: (20)
Also your getting kinda of a rise in PSI.
Its running 23psi at redline.
Old 10-23-2009, 07:20 PM   #10 (permalink)
Well, my gauge on the boost controller is saying 20.5psi and it was dead on on the dyno. Something might be going wrong with it or something. How is it that you said that I can read psi with the diablosport?
Old 10-23-2009, 07:32 PM   #11 (permalink)
Kason23's Avatar
Trader Rating: (20)
ADV map to use minus BARO.. And I would go by that...
Old 10-23-2009, 07:42 PM   #12 (permalink)
Ok, I will try that out. Hell, if it is rising that high, that's probably why i'm getting knock then. Damn that will suck if I have been running 23psi this whole time getting use to it and have to turn it down, it will feel like a turd.
Page generated in 0.21048 seconds with 13 queries
