Old 10-05-2009, 11:08 PM   #1 (permalink)
SonnySrt-4's Avatar
Member Number: 34315
Trader Rating: (10)
Default 1st - 3rd gear pull delta44/log (KASON23 come in)
Feels great afrs are all in the low 11's even 10.8's no timing is added can I advance some timing? looks like zero kr with my meth kit. ran it from first to a lil bit of thrid gear. Kason23 please chime in.
Deposit Files
Edited by Inzanesrt4
Agp s3d-44lb turbo kit
38mm TurboSmart Wga
3inch bdj's catless down pipe dumped exhaust
BFMIC
N2MB Boost box (GET ONE!!!)
D/O Meth/Alchy injection m5
DSP tuner
800cc injectors
HKS bov and hard pipe
SonnySrt-4 is offline   Reply With Quote
Old 10-06-2009, 12:08 AM   #2 (permalink)
duster360's Avatar
Member Number: 45182
Your baro is still jacked up at over 19psi. Weren't you going to fix that? I strongly suggest you do. Not only can you not tell what your boost is in the log, an incorrect BARO screws with your fuel. Which is probably why your commanded A/F is 9.8 when the actual A/F is in the low 11s.
Your ACT are too high to be using meth unless your nozzle is improperly placed.
ps. don't forget to shift
Old 10-06-2009, 01:08 AM   #3 (permalink)
SonnySrt-4's Avatar
Trader Rating: (10)
yeah lol first pegged the limiter for a split second...redline came on almost instantly in first on 8 psi...First gear is awesome on low boost it actually useful... I pulled on a 420whp 15psi procharged gt from a dig believe it or not.. I did not hit the limter on that run though lol
boost is controlled by the N2mb box and its 8-19-23-22-22 per gear. I have 800cc injectors no returnline and when I installed them with turbo666 rescale I was a tiny bit on the lean side (11.0 11.8 depending on boost in that specific gear) I added a tiny amount of fuel now I am looow 11 top of third at 23 psi and in the 10's and high 9's through out the other gears with the lower boost ranges.It feels right I just want to know if I can add some timing to it since I have no knock. As far as the meth goes I have it set to come on at like17 psi the act could it be that high because it was started in my drive for about 30 mins before I ran it.
Old 10-06-2009, 07:58 AM   #4 (permalink)
duster360's Avatar
You need to fix the BARO
Old 10-06-2009, 11:47 AM   #5 (permalink)
SonnySrt-4's Avatar
Trader Rating: (10)
I understand that.... And it would be fixed if I had the cash for the tip sensor. I still need a good $700-$900 for a good clutch. Then I will get the tip sensor and dyno tune.
I spent alot of cash so far and just want to enjoy the car for now, and it seems like its running great and the afr's are good so I do not see the immediate need. Basically I feel like I have to get a clutch before I drop another 120ish on a tip sensor.
I am not sure if a 3bar tip will even fix that reading because the wires going to the tip sensor or no longer connected to it the N2mb box taps into those wires and if I remember correctly a resistor was wired in to one of the wires...
Alll I want to know is can I advance some timing through out the rpm range.
Old 10-06-2009, 12:49 PM   #6 (permalink)
Gizmodo's Avatar
Member Number: 22931
You can get 3 bar tip sensors for about $60.00. Just because the car "seems" like it is running well does not mean it is running right. As Duster said, baro is very important in most things the PCM does.
Gizmodo is offline   Reply With Quote
Old 10-06-2009, 01:38 PM   #7 (permalink)
SonnySrt-4's Avatar
Trader Rating: (10)
if I can get it for $60 I will pick it up... Please lmk wher I can get it for this price!
ps I do not doubt Duster a bit, I actually think he is one of the more knowledgeable guy in this section.... I vote mod for him
Old 10-06-2009, 03:38 PM   #8 (permalink)
Gizmodo's Avatar
PT-Performance.com
Old 10-06-2009, 03:45 PM   #9 (permalink)
93stang434's Avatar
Member Number: 49690
You should not have cut the wires for the tip sensor only spliced the boost box into them.....the boost control solenoid wires get cut and the resistor wired in there.
E1 w/ported 3" anti-surge cover,LCR fully ported ext.gated exh mani,3" o2 housing,3"SEE,N2MB boost box,
S2 injectors,diablosport predator,coolingmist w/m
255 pump,rewire,bottleneck mod,returnline
MPx bfmic,55 t-body,180 t-stat,DCR oil restrictor
Best E.T 12.12 Best MPH 118.71 DR's,full weight no n2o
Tuned by Nemo@Rage-Tek & myself http://www.srtforums.com/forums/f146...charts-480643/
93stang434 is offline   Reply With Quote
Old 10-06-2009, 06:09 PM   #10 (permalink)
SonnySrt-4's Avatar
Trader Rating: (10)
well thats what I did then.... I followed the instructions to the tee...works great BTW.
Old 10-06-2009, 06:12 PM   #11 (permalink)
93stang434's Avatar
Cool deal and yes it does work great....the best thing i've gotten for the car in awhile.
Old 10-06-2009, 07:00 PM   #12 (permalink)
Kason23's Avatar
Member Number: 34502
Trader Rating: (20)
Its looks decent..well as good as it can be with the baro jacked up. Your timing looks a way to low to be running meth. My timing on 93 pump alone was 3* higher then yours. Its your graph is just all over the place lol. Def get the TIP sensor and add more timing.
Where is your W/M nozzle located at?
Tuned By TDSAaron!!
My Goal: 100+Mph in the 1/8
Old 10-06-2009, 07:13 PM   #13 (permalink)
Kason23's Avatar
Trader Rating: (20)
Here is a comparison between ours just for measure.
Mine is on top while yours is on bottom.
Old 10-06-2009, 09:45 PM   #14 (permalink)
SonnySrt-4's Avatar
Trader Rating: (10)
it is a single nozzle placed right near the exit tank of the intercooler on the coldside.
The stupid nozzle maybe clogged or my damn check vavle may be screwed again. but it does show that it is spraying via the progressive controller.
Old 10-06-2009, 09:48 PM   #15 (permalink)
SonnySrt-4's Avatar
Trader Rating: (10)
oooh damn. I see now. Well fuk I guess I need to hit up ptp for a 3bar tip as long as its under a $100 I could spring for it.
Page generated in 0.21634 seconds with 13 queries
