You will need spring compressors..
Don't cut the bumpstops...
You will need new rear endlinks.. Autozone carries new ones..
Pretty straight forward fronts have 3 bolts on the tophat and two on the strut assembly. Also one 10mm for the abs cable...
Rear has 3 also for the top hat and two for the strut assembly. for the rears I usually take off the caliper to get to the two bolts.. May or may not be needed..
Let me know if you run into any snags..
Quote: Originally Posted by carverSRT
My springs finally came today and me and my neighbor with a turbo GSR are installing them tommoroww. I don't have any expierience with springs but he iinstalled some on his Integra and other people's Integra's.
So do you guys have any tips or any tricks to make the install easier?
There was no how to for srings in the How-to section. Just IPP coilovers.
Thanks, Josh
