Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Regional Forums > Regional Forums 2 > New England
Old 10-09-2009, 07:19 PM   #1 (permalink)
boneriffic's Avatar
Member Number: 60776
Trader Rating: (23)
Default need help with wiring
my car won't start because the dtec stopped working. i need someone to rewire it for me so that i can try to drive my car. the meth pump also stopped working a month ago which i believe is the wiring too if someone can rewire that too i'd be happy
Fothermucker.
boneriffic is offline   Reply With Quote
Old 10-09-2009, 11:11 PM   #2 (permalink)
stage3matt's Avatar
Member Number: 54658
i bet the DTEC is dead. It was in kinda rough shape when it went in.
Take the brown wire and green wire from the dtec and attach them together. The car isn't getting MAP signal and keeping it from starting. Are you going Saturday? If you can get your car started by then bring it and I will fix it for you.
2009 1320x threads:
III
stage3matt is offline   Reply With Quote
Old 10-10-2009, 01:53 PM   #3 (permalink)
Senior Moderator
SRT of the Month
uncommon©'s Avatar
Member Number: 39843
Trader Rating: (167)
why does his battery keep dying though?
Old 10-10-2009, 05:57 PM   #4 (permalink)
stage3matt's Avatar
that part doesn't make sense.
Do you have a multimeter Nate? Set the meter to Amps, take the positive terminal off the battery, and put the meters leads in series with the cable and the positive post. If there is any draw (anything over say like 2 amps) then pull fuses until it drops off and you have found the circuit in question.
I forgot how exactly I powered the pump and dtec (I think the dk blue IGN wire at the ignition harness) so either of those wouldn't make any sense unless the ign switch was shorting and sending 12v down the switched 12v wire all the time, however you would be able to tell because the fuel dash lights (abs, cel, ect.) would be on with the keys out of the cylinder.
I am off monday and tuesday so I could swing through salisbury and check it out if you need me to.
Page generated in 0.13164 seconds with 13 queries
