Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Regional Forums > Regional Forums 2 > New England
Old 11-15-2006, 12:57 AM   #1 (permalink)
JonnyButt's Avatar
Member Number: 35259
Default Foggy Ass Windows - Any Help?
My windows seem to get foggy as hell
Anything I can do or put on them to help it (that is safe to put on tint?)
Usually I crack a window or some shit like that to help vent the car but j/w
JonnyButt is offline   Reply With Quote
Old 11-15-2006, 02:28 AM   #2 (permalink)
htheduck's Avatar
Member Number: 10205
-Howard
_________________________________________________
94 Taurus SHO: K&N, Eibach/Koni, ATE Super Blue, FPS: Alum SFB, SFC, 96 Brakes/Porterfield R4
94 Integra LS: K&N, Neuspeed/KYB, F&R STB, Rear LTB
04 SRT-4
htheduck is offline   Reply With Quote
Old 11-15-2006, 05:53 AM   #3 (permalink)
06Limit's Avatar
Member Number: 43104
when mine fog up i just keep the heat on and swtich it to AC. or just turn the dial to the defroster symbol. i hear that rainx stuff works good though.
06Limit is offline   Reply With Quote
Old 11-15-2006, 06:47 AM   #4 (permalink)
Member Number: 14149
Every Noen I've ever ridden in gets fogged up.
My friends 99 is just as bad as my SRT.
When the weather started to get cold, I unhooked the clutch
connector on the AC compressor and ran my defroster all the time.
It must be a bad design where air enters the cabin, must get alot of
water in that area.
04 SRT-4
86 GLHT- 13.17@ 95.85
keito is offline   Reply With Quote
Old 11-15-2006, 07:07 AM   #5 (permalink)
New England Moderator
ptc01's Avatar
Member Number: 1771
water in that area.
You got that right, all these years and they never got it right . . . Foggy Neons! It seems to be a trade mark of all Neons. My daugthers 1st gen was exactly the same.
2005 Import Wars Slick Class Champ New England Dragway
2006 SRT Nationals Champ Heartland Park Topeka Kansas
2006 Class Winner Englishtown New Jersery
2006 Top Eliminator Englishtown New Jersery
2003 Flame-Red SRT-4
BEST TIME:11.51
Best MPH: 122
Best 60': 1.673
MODS: Darrell Cox Racing Built.
ptc01 is offline   Reply With Quote
Old 11-15-2006, 08:32 AM   #6 (permalink)
MattG's Avatar
Member Number: 18339
water in that area.
Why did you do that? To stop the shaking if you have solid mounts i am assuming.
Otherwise under WOT the ECU shuts off the compressor for the demand of power...
Mods: Stage 1, AGP WGA, Apexi SAFCII, Aeroforce Scan Gauge, Boomba Motor Mounts, JMB UPP, HKS SSQV, AEM Short Ram Intake, AEM UEGO Wideband, NGK Copper Plugs, Needswings Downpipe (dp closed), DeatschWerks 750cc Injectors, Walboro 255lph Fuel Pump, Autometer 30 PSI Gauge, Maddog STS, 17" G-Racing Seki Gloss Black.
301whp / 388ftq - Dyno
MattG is offline   Reply With Quote
Old 11-15-2006, 08:36 AM   #7 (permalink)
Junior Moderator
Jmhm17's Avatar
Member Number: 24437
when your defroster is on it automaticly turns on the AC.. regardless of the temp setting..
hence the random "shacking" every 30 seconds.. (if you have mounts)
why dose it turn on the AC if your useing heat??
* Disclaimer...The above post may or may not have misspelled words ...deal with it...
**Sold**
Best E/T 12.699 @ 108.97
Best MPH 12.856 @ 110.32
Jmhm17 is offline   Reply With Quote
Old 11-15-2006, 08:39 AM   #8 (permalink)
thepowertowin's Avatar
Member Number: 13897
Trader Rating: (620)
AC also removes moisture (AKA FOG) so leave it plugged in for sure...
ALL MOPAR AND MOPAR PERFORMANCE PARTS!!!!
James "Jimmy" Campbell
E-mail/Paypal: speedandpowerdevelopment@gmail.com
Email is better than PM's
http://www.srtforums.com/forums/f165...12/?highlight=
thepowertowin is offline   Reply With Quote
Old 11-15-2006, 09:38 AM   #9 (permalink)
Junior Moderator
Jmhm17's Avatar
ah makes sence now..
Old 11-15-2006, 10:15 AM   #10 (permalink)
Member Number: 20951
Trader Rating: (65)
I use that FogX stuff too, it works pretty good. Takes a while to apply well.
[live]Jabbit[/live]
Jabbit is offline   Reply With Quote
Old 11-15-2006, 10:27 AM   #11 (permalink)
Maxx Racing Zero's Avatar
Member Number: 21123
i tried using the fog x stuff but it crapped up my windows... left a oily residue, and actually made night time visibility worse than regular foggyness...
i dont like the stuff... my 2 cents...
1990 Nissan 240SX Fastback...
SR20DET>KA24E
Thats right, its one color.
Maxx Racing Zero is offline   Reply With Quote
Old 11-15-2006, 11:15 AM   #12 (permalink)
Junior Moderator
Jmhm17's Avatar
ya it also goes away after you clean it with windex but the resedue stays causeing glaring at night.. i wouldent recomend it.. the only thing i can recomend is shut the fan off set the switch so its sucking air in from outside and put it on heat.. when the car is driving it will pull air in and keep the windsheild regulated so it wont fog. the other problem is you could have your heat on researqulate which causes fogging.. (this is stated int he owners manual)
Old 11-15-2006, 11:19 AM   #13 (permalink)
Senior Moderator
1badsrt-4's Avatar
Member Number: 21276
Trader Rating: (53)
I use windex and newspaper to clean my windows. I use the news paper instead of paper towels. Trust me it works, it gets rid of it for about 2-3 months then you have to do it again
11.34 @ 128.33 mph. Stock motor, head, cams and ecu
1badsrt-4 is offline   Reply With Quote
Old 11-15-2006, 12:00 PM   #14 (permalink)
Trader Rating: (65)
Yeah I have had that happen before. You really need to clean the windshield well before applying the fogx. And you have to buff it like crazy once its on there. It takes a long time, but it works well. Tim's method is old school but def. works like a charm too. A lot quicker as well.
Old 11-15-2006, 12:10 PM   #15 (permalink)
Senior Moderator
Nick Fury's Avatar
Member Number: 19761
+1 I thought I was the only one who used Newspaper Works awsome
Need Boost
Nick Fury is offline   Reply With Quote
