Shouting out for a MI fella for some help
Hey fella's,
Heres the inside
I have a dodge neon srt4 stage 3 setup. I decided I wanted to clean up the engine bay with all the wires and hoses. I decided to re-do the vacuum lines for a cleaner look. Well I know installing this setup I had a diagram... not sure of what type of setup.. but it was to give me the most and best out of the setup with the pcm not controlling the boost.
Well, the day came I gripped up a diagram... Now I find out its the stock vacuum line setup. I won't boost over 12-15 psi in option 1, 2, and 3.
I did alot of research with no results, but I did read up on some stage 1 vac line setup. I was just wondering if anyone in the Area from Dearborn here could possibly meet up and give me a chance to compare the vac setup or possibly throw some advice. I have been trying for 8 days now cancelling out as many options I could come up with.. surge valve, mopar bov, boost tested a hundred times.
If anyone is up for it, or possibly has what I have been looking for, for a long time now.. you wouldn't understand how much i would appreciate it.
Thanks
(GO BLUE!!!)
