Michigan thread - Page 342 - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Regional Forums > US Regional Forums > Midwest
Old 11-29-2012, 05:27 PM   #5116 (permalink)
TmP
TmP's Avatar
Member Number: 59394
That sounds like BS to me...
Not sure about the rods though.
You said Dodge 2.4, not Chevy 383 stroker, right? ROFL
Signature. Dum di dum
TmP is offline   Reply With Quote
Old 11-29-2012, 06:54 PM   #5117 (permalink)
SRTForums Member
2011 Calendar Car
ry.david's Avatar
Member Number: 48109
I am not sure what he is referencing but I used those same rods without issue. Just make sure your crank journals are in spec (diameter and eccentricity) and use plastigauge to verify
ry.david is offline   Reply With Quote
Old 12-05-2012, 02:59 PM   #5118 (permalink)
rednblack04's Avatar
Member Number: 84924
ry.david what cams are you running and do you have the head ported? Nigel suggested crane 16 and bob suggested bc stage 3 not sure which I will use yet. I'm gonna do MAP stage 3 head with +1 +2 valves any suggestions
rednblack04 is offline   Reply With Quote
Old 12-05-2012, 07:18 PM   #5119 (permalink)
Tiger Wu's Avatar
Member Number: 41629
Ive had sucess with crower s3.
S2/S3 Hybrid 11.6 @ 121
Stock turbo no n2o - 12.0 @ 115
Tiger Wu is offline   Reply With Quote
Old 12-05-2012, 08:14 PM   #5120 (permalink)
SRTForums Member
2011 Calendar Car
ry.david's Avatar
/\/\ Another good data point, Wu is obviously making them work great
I am running BC S2 cams with DCR Pro head... I wanted to stay pretty mild with the cams so my powerband didn't shift too far to the right. As it sits, my torque starts falling off around 7100 RPM
Old 12-06-2012, 07:18 PM   #5121 (permalink)
I think crower 3s might be a little too big for what I'm doing but thanks for the suggestion. Like you ry I want to keep my power band from moving up too high in the rpm range. I will probably just go with Nigel's suggestion since he will be the one tuning the car. Thanks for the input though guys.
Old 12-08-2012, 08:03 PM   #5122 (permalink)
http://www.google.com/url?sa=t&rct=j...h_0i_5f8pMkdQQ
Any thoughts on this
Old 12-08-2012, 09:22 PM   #5123 (permalink)
Tiger Wu's Avatar
Quote: Originally Posted by rednblack04 View Post
They've been using a corn blend fuel since 2006. Nothing really new.
Old 12-09-2012, 08:55 AM   #5124 (permalink)
DetroitSRT's Avatar
Member Number: 66615
How do you guys think this battery would perform for spring/summer/fall weekend driving? I'd have a trickle charger on it over the winter. Should be able to save quite a bit of weight.
Braille Battery USA &nbsp&nbsp&nbsp&nbsp Lighter • Stronger • Faster -
11.87@116.4 - stock turbo no N2O
http://youtu.be/yP6xoSjgWbA
DetroitSRT is offline   Reply With Quote
Old 12-09-2012, 09:43 AM   #5125 (permalink)
I didn't know that my friend just told me about this sunoco E85R and i was searching about it. It is really expensive but would be more consistent on a race level.
Old 12-09-2012, 10:44 AM   #5126 (permalink)
SRTForums Member
2011 Calendar Car
ry.david's Avatar
I am thinking it will be fine. Careful though, PCA != CCA... different test parameters.
Old 12-09-2012, 11:03 AM   #5127 (permalink)
Tiger Wu's Avatar
Bring the battery in the house for the winter. Trickle will burn up if you just place it attached to the car in the garage. I put mine in the basement on a charger.
Old 12-10-2012, 05:39 AM   #5128 (permalink)
TmP
TmP's Avatar
I have a Braille. Lost one over the winter before...
My routine now: Charge it once every 2 weeks or so.
Old 12-10-2012, 09:46 AM   #5129 (permalink)
DetroitSRT's Avatar
which one do you have? you have it in 4DRGOAT? did you let it sit all winter and not charge it? I'm hoping to buyy the smallest one. it's only 6.9lbs. I'm going to call the company today and get their input
Old 12-10-2012, 11:24 AM   #5130 (permalink)
Member Number: 35677
Default Rust question
Michigonians - with your enourmous supply of water around, do you get rust problems? Or is it salt air more the culprit?
ValleyRacer is offline   Reply With Quote
