Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Regional Forums > Regional Forums 1 > Midwest
Old 11-06-2004, 03:06 PM   #1 (permalink)
Member Number: 14020
Default I keep over boosting
Well I just put on a AGP wastegate on my car. It doesn't matter what adjustments I do I keep getting over 20 pounds boosts. Help what can I do
blackturbosrt4 is offline   Reply With Quote
Old 11-06-2004, 03:27 PM   #2 (permalink)
Member Number: 6337
just keep backing the adjustment off, make the rod longer and make sure the line didnt blow off where your getting your boost for the wga
srtpvo is offline   Reply With Quote
Old 11-06-2004, 03:46 PM   #3 (permalink)
Member Number: 1849
More info needed. What line are you using are you using the stock line green blue manifold source? Just keep backing it down like he said and check all your connections.
Quote: Originally Posted by engrishmofaka
HA! I got the oil out without taking the nut off. My car probably hates me now though. I just unscrewed the oil filter and turned the car on. Makes a mess because oil sprays everywhere, but I got the shit out of the car. Filled it up with mobile one and yeah.
VeGeTa is offline   Reply With Quote
Old 11-06-2004, 11:37 PM   #4 (permalink)
SRToc Member
iupui1299's Avatar
Member Number: 2187
Trader Rating: (12)
What lines are you using? And stage 1 would help.
iupui1299 is offline   Reply With Quote
Old 11-07-2004, 12:23 AM   #5 (permalink)
Member Number: 13788
i thought u were waiting til stage 1
Matt20_srt4 is offline   Reply With Quote
Old 11-07-2004, 12:26 AM   #6 (permalink)
SRToc Member
iupui1299's Avatar
Member Number: 2187
Trader Rating: (12)
Are you throwing a CEL? You shoudl throw one for over boosting since you are at stage 0.
Old 11-07-2004, 01:00 AM   #7 (permalink)
DaZone's Avatar
Member Number: 1799
you must be using the blackline. Or your adjustment nut broke off the rod arm.
Mods: S3w/toybox,CTI turboback,Iceman TB,AGP CAI,CCA Fmic, Mopar wires w/NGK Plugs. Turbonetics w/greddy type s bov. also: B&G Lowering Springs, Front&Rear Strut tower bar, Rex motor mount inserts, Progress Rear sway bar. AGP S3 Wg.
18" Exel Chromes w/toyo proxes 4
17" Nexo PX-5 w/ toyo proxes 4
Dynoed with HOM : 358hp and 359tq
DaZone is offline   Reply With Quote
Old 11-07-2004, 08:34 AM   #8 (permalink)
well I decided to put it on with out stage one and just keep it at 15 psi. Till stage one comes in but I am hitting way over 20 psi.No matter what adjustment I make it just flys off the scale. and yes I over boosted and the check engine light came on. But I dissconnected the battery and its off now.
Old 11-07-2004, 02:00 PM   #9 (permalink)
mprtklr's Avatar
Member Number: 10011
Trader Rating: (25)
how much space between the nuts?
mprtklr is offline   Reply With Quote
Old 11-07-2004, 03:17 PM   #10 (permalink)
IH8MYWRX's Avatar
Member Number: 10526
This may sound dumb, but are you sure you're turning it the right way? I guess keep at it. When I first put mine on, if I had one because that would void my warrenty, I had to adjust it for a while until I finally got it to come down from 20 lbs.
Best 60' 1.804
Best run 60' 1.8339 1/4 12.504 @ 110.22
Dyno-Jet: 294Hp/348Tq
There may be a DBB 50 trim that's been added since then...
IH8MYWRX is offline   Reply With Quote
Old 11-07-2004, 04:19 PM   #11 (permalink)
SRToc Member
iupui1299's Avatar
Member Number: 2187
Trader Rating: (12)
Take it off and wait until stage 1....you dont want to blow something up.
Old 11-10-2004, 03:26 PM   #12 (permalink)
thepowertowin's Avatar
Member Number: 13897
Trader Rating: (612)
Be sure the diapragm isn't ripped/torn, and that all your vacuum lines are secure.
ALL MOPAR AND MOPAR PERFORMANCE PARTS!!!!
James "Jimmy" Campbell
E-mail/Paypal: speedandpowerdevelopment@gmail.com
Email is better than PM's
http://www.srtforums.com/forums/f165...12/?highlight=
thepowertowin is offline   Reply With Quote
Page generated in 0.28389 seconds with 13 queries
