Because it just helps me remember all whats done. Easier to put ported then, smoothed.
Whats the clutch have to do with anything. I got a good deal, I put it in to be safe.
Want to see the stock clutch, still perfectly fine when it was taken out.
A better clutch will:
1) put the power to the ground
2) gives you better revs when you switch gears and launching or taking off
3) is safer in case you have to much power it doesn't explode during a burnout or something similar.
i have a MPx dual exh...3" all the way, from down pipe to tips...1 resonator...2 bungs...near 7k miles on the system...only issue, it vibrates on one of the flanges, can be fixed for about 30 bucks at a exh shop or else free by yourself.
24.5" M&H slicks on 15" lightweight kosei's plus spacers for sale. About 20-25 passes use. Lots of rubber left. First $300 bucks takes them picked up in Crescent Springs. Call Charles 859-445-2778.
Killer deal someone should jump on...now.
Brand new agp return line and brand new pwerks bottle neck fix with correct fittings for sale from charles. I think he said he wanted 350.00 for both picked up? Call him up if you are interested. 8594452778
