I have a GTX 280 and I have an HDMI cable which is hooked from my vid card to my tv but for some reason it looks like complete crap and i can only clone my desktop. any idea what the issue is?
If you can only clone, it sounds like you're trying to run both a monitor and the TV at the same time?
Go into your display properties to the Settings tab. You'll see two monitors on the little display. Click the TV (it will probably be your secondary) and check the resolution. It might be set too low. Also while you have the TV selected, the checkbox at the bottom that says "Extend my Windows desktop on to this monitor" is what makes your screen an extension of the primary, rather than a clone.
2008 Mazdaspeed 3
- Cobb SRI, Short Shift Plate, SU Solid Shifter Bushings, 18x8 Konig Runaway's 2008 Kawasaki Z1000
- Laser X-Treme Exhaust, -1 Front Sprocket, Speedohealer, Renthal Ultra-Low Bar, CRG Bar End Mirrors, Pazzo Levers, Motovation Frame Sliders, Targa Fender Eliminator, OEM Rear Cowl 2001 Kawasaki Ninja 250
- For sale soon...
When I go to the settings tab there is no secondary display. I setup quite a few double and triple monitor displays at work using a shitty ATI PCI graphics card and it gave me no issues, why the hell am I having such a hard time with this more advanced card
Okay I got it to work after restarting but still have an issue with it looking like poop. I've changed the resolution on it to different things but still nothing good. It's a toshiba 37 inch tv (non 1080p, just a regular 720p i know gay).
It only looks half decent on 800x600
800x600 is a 4:3 resolution so you're getting a stretched image. set it to the closest thing to 720p (1280x720 ) .. and if for some reason your card doesnt support that,.. at least choose one thats close and 16:9
Yeah that is what I did. So far it's running fine. Now to figure out how to run a game while browsing the internet lol
I can't wait until I can afford a 1080p TV. This TV isn't using the card's max capability at all
a) Since you are clearly overclocked, it is difficult to diagnose lag without resetting your clock speed to factory default, and ensuring that the lag still exists.
b) Have you tried to OC the video card? Changed anything?
c) Are your drivers up to date for the card?
d) Try to go into the Nvidia control panel and set your resolution rather than using the windows display setting control panel. I believe with your card you can even CREATE your own resolution, and the card will attempt to use it.
As long as you are cloning, if it doesnt recognize the secondary display, it will use your native settings on your primary display. Good luck. The 280 is a great card.
Quote: Originally Posted by o5socalsrt
Good thing you put what intake manifold gasket your using on your mod list... If that wasn't there I would think that your slow......
O.T. - Only Ten(Number of people allowed to post in the off topic section)
