Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Off-Topic Area > The Water Cooler > Gaming and Electronics Discussion
Old 10-06-2009, 04:51 PM   #1 (permalink)
ShiRoTor4's Avatar
Member Number: 16491
Default Major PC problem. Need help!
So I've been having random problems with my pc resetting itself recently. I think it may be software related so I get a registry cleaner/repairer. Says I have 1100+ errors so it fixes them and I restart. Pc works fine for about 45 mins until it resets itself again.....and again....And again, infinitely. So I try to do a repair with windows xp.... But it won't read the damn disc. I get a black screen with blinking cursor only. Then it tries to boot up xp from the hard drive. (my friends genuine xp disc)
I figured out how to see the blue screen error and it says: IRQL_NOT_LESS_OR_EQUAL 0x0000000A (0x00000000, 0x0000001C, 0x00000001, 0x0804FB03C)
in safe mode it still resets and in debugging mode I can get to the desktop but it freezes before anything loads...
keep your signature safe for work
edited by peteblksrt4
ShiRoTor4 is online now   Reply With Quote
Old 10-06-2009, 05:22 PM   #2 (permalink)
sphipps's Avatar
Member Number: 19187
Trader Rating: (13)
once again...my dumpster diving PC > yours.
JPG
Quote: Originally Posted by Illegal Machine View Post
I'd like to see Steve's craigslist ad.
"Like new. Comes with 4 jack stands."
sphipps is offline   Reply With Quote
Old 10-06-2009, 06:19 PM   #3 (permalink)
BLKDOUTSRT4's Avatar
Member Number: 36285
get windows 7......winner !!!!! looooove this os
Quote: Originally Posted by Alpha-Omega View Post
....yeah, I'm gay and staying home this time
BLKDOUTSRT4 is online now   Reply With Quote
Old 10-08-2009, 03:59 AM   #4 (permalink)
Adionik's Avatar
Member Number: 51197
Trader Rating: (25)
I'd just reload the OS...but that's me. I'm lazy.
or 16 whatev
WTB: LCA bushings
Old 10-08-2009, 10:19 AM   #5 (permalink)
yah clean hd format and fresh os will fix ANY problem thats why i have my hdd in 2 pieces one big part for downloads and the c drive is JUST os thats all so if something messes up i can format c reinstall windows and all my files stay safe
Old 10-09-2009, 01:03 AM   #6 (permalink)
SRTie4k's Avatar
Member Number: 45499
Trader Rating: (53)
The IRQL_NOT_LESS_OR_EQUAL 0x0000000A means you have a driver that is trying to use an incorrect memory address. Unload all of your drivers one by one in safe mode until you fix the problem, then find an updated (or older if already up to date) driver to replace it.
2008 Mazdaspeed 3
- Cobb SRI, Short Shift Plate, SU Solid Shifter Bushings, 18x8 Konig Runaway's
2008 Kawasaki Z1000
- Laser X-Treme Exhaust, -1 Front Sprocket, Speedohealer, Renthal Ultra-Low Bar, CRG Bar End Mirrors, Pazzo Levers, Motovation Frame Sliders, Targa Fender Eliminator, OEM Rear Cowl
2001 Kawasaki Ninja 250
- For sale soon...
SRTie4k is online now   Reply With Quote
Old 10-09-2009, 04:12 PM   #7 (permalink)
ShiRoTor4's Avatar
Well my Dual layer DVD drive is SATA and won't show up in BIOS so I can't do an XP disc repair (which is odd because all 3 hard drives are SATA). My other drive shows up (regular IDE) but it won't load the windows xp disc. It just sits on a black screen with a flashing underscore for awhile and then boots from the hard drive.... Which blue screens as soon as the XP logo goes away...
I have another IDE DVD drive I'm gonna try and hopefully that'll let me load the xp disc.
Old 10-10-2009, 09:15 AM   #8 (permalink)
SRTie4k's Avatar
Trader Rating: (53)
You sure your BIOS is set to boot from the CD Drive as primary? Also are you sure that your copy of Windows is a good copy?
If you can get into safe mode, you might not even need the Windows CD. You can uninstall certain driver packages in safe mode, like video, sound and chipset typically. Those might fix your problem. If it's an integrated controller driver though, you might be SOL unless you reinstall your OS.
I would check your device manager as well as the event viewer in safe mode to see if there is any error reporting that can help you ID the driver that's causing the BSOD.
Old 10-10-2009, 01:51 PM   #9 (permalink)
ShiRoTor4's Avatar
Nope, can't even get into Windows. It blue screens as soon as it tries.
Yes I do have the boot order starting with my DVD rom drive and the copy of Windows was bought from best buy and already used in my friends PC so it should be fine.
Old 10-10-2009, 02:22 PM   #10 (permalink)
Adionik's Avatar
Trader Rating: (25)
Same here.
My OS drive is a WD Raptor 74GB, my slave is a 250GB I think. I just keep all the drivers and programs on there...so reformats are extremely easy.
Old 10-10-2009, 07:22 PM   #11 (permalink)
SRTie4k's Avatar
Trader Rating: (53)
74GB Raptor primary, 750GB WD and 1TB WD Black secondaries FTW
Shirotor4, sounds like you'll just have to find a new drive and deal with reformatting.
Old 10-11-2009, 09:47 PM   #12 (permalink)
ShiRoTor4's Avatar
I put in a different DVD drive and it loads the xp disc (thank god) but when I do the repair what do I do for the admin password? I never put a password in. When I leave it blank it brings up C:\Windows>
The hell am I supposed to do?
Old 10-11-2009, 10:36 PM   #13 (permalink)
SRTie4k's Avatar
Trader Rating: (53)
Well you can always try "chkdsk /f" which will check the hard drive for corrupted clusters and try to fix them, but I don't think that is your problem.
Rather than going to the repair console, I would go through the windows setup like normal. At some point windows will search for an existing installation and it should find yours, then you can choose to repair the installation. That might take care of your problem.
Old 10-12-2009, 02:23 PM   #14 (permalink)
ShiRoTor4's Avatar
Well I did the repair... Now it wants me to activate it before I can do anything else.... Unfortunately it shows my desktop wallpaper and just sits there and does nothing..... WTF?
Old 10-13-2009, 12:03 PM   #15 (permalink)
SRTie4k's Avatar
Trader Rating: (53)
Sounds like explorer is not booting.
Once you see your desktop, hit Ctrl-Alt-Del, open the Task Manager, go to File -> New Task (Run...) and type in explorer.exe
That should start the shell.
Page generated in 0.18093 seconds with 13 queries
