Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Regional Forums > Regional Forums 1 > Northwest
Old 03-04-2006, 03:23 PM   #1 (permalink)
monkey_SRT's Avatar
Member Number: 24042
Default Ticking noise when partially warmed *help pls*
My car has a ticking noise that I am unsure what it is. It is NOT the normal injector tick and it isn't the throw out bearing on the clutch. It only happens in certain temperature ranges. Typically I notice it when the car is around the 1/4 mark on the temp gauge. A lot of times it is when I start the car after it has sat for an hour or so. Once the car warms up fully, the noise goes away.
The noise itself sounds kind of like a lifter tick. Kind of metallic and intermittant, not rythmic. I noticed it when the car was just a few weeks old (now 11k miles). My dad and I talked about it when the car was new and figured it was everything still breaking in and should go away once the car was fully broken in. With 11k, the car is broken in, but the noise still exists.
Any ideas? I am not too worried since it only does it for those few minutes when the car is partially warm. My old Saturn made a very simlar noise for the 50k miles I owned it, only it did all the time at idle once fully warmed. But if it is something more serious, I want to know before I start modding and get my warrenty voided.....
2005 Silver SRT-4
monkey_SRT is offline   Reply With Quote
Old 03-04-2006, 03:31 PM   #2 (permalink)
bsbob's Avatar
Member Number: 5248
Trader Rating: (26)
chrysler TSB #09-007-04 irregular snapping sound. i did mine myself but the stealership can do it for you too. BSBOB
bsbob is offline   Reply With Quote
Old 03-04-2006, 03:34 PM   #3 (permalink)
Member Number: 28516
what is it, mine does it too, but I thought it was normal
ODHANZ is offline   Reply With Quote
Old 03-04-2006, 03:41 PM   #4 (permalink)
bsbob's Avatar
Member Number: 5248
Trader Rating: (26)
the TSB is for improper machining of the cam caps.you can do yourself with some minor mech ability, the service bulletin and a small hand file. BSBOB
Old 03-04-2006, 03:42 PM   #5 (permalink)
i see,
thanks
Old 03-06-2006, 01:55 PM   #6 (permalink)
GreyGhost2's Avatar
Member Number: 33657
I have been there and done that. Two years ago my car was making that tapping sound around a 1/4 on the temp guage. After a ton of hassel with the dealers excuses for the noise (they were blaming the sound on a non-mopar oil filter I had put on, said it was causing irregular bleeding on the cam) they fixed the problem. They told me that the cam bearing caps were too tight and they replaced all of them. I was told that there was a recall on the problem but only if you bring the car in and complain about the sound. Best of luck with it, they had my car for 5 days and refused to give me a rental, but they did fix the problem and it has never come back.
GreyGhost2 is offline   Reply With Quote
Old 03-06-2006, 09:56 PM   #7 (permalink)
monkey_SRT's Avatar
Yeah, that is what I am afraid of. I can see them blaming it on my K&N drop in and Mopar wires.
What is up with Dodge dealers and not giving rentals when a car is in for service? Saturn of Spokane blows chunks, but at least they gave me a rental everytime they broke the car and had to fix it.
Old 03-07-2006, 11:24 AM   #8 (permalink)
SRToc Member
jaymzx's Avatar
Member Number: 278
Trader Rating: (12)
The noise is just a noise. I have it, and have had it since day 2 of owning the car.
The lead mechanic at the local dealership said the TSB would fix my problem, but I would be better off not opening the head and tearing it down just to fix a little tick. I may come out with more problems than I went in.
James
READ AND LEARN:
Old 03-11-2006, 09:54 PM   #9 (permalink)
Member Number: 2110
I have access to all the TSB's, so if you need a copy, i can email it to you
2002 Blackout Nissan Sentra SE-R Spec V with AEBS Header (downpipe and high flow cat) AEM cai, Unorthodox Underdrive Crank Pulley, 7000k HID, Red Calipers *SOLD*
QR25SpecV is offline   Reply With Quote
Old 03-12-2006, 01:47 AM   #10 (permalink)
monkey_SRT's Avatar
thanks, but I found the TSB here in the forums.
I think I am just going to ignore it. The car only does it in a very specific heat range, and it is only in that range for 2 or 3 minutes. The dealership would probably play stupid anyway......
Page generated in 0.23816 seconds with 13 queries
