Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Regional Forums > Regional Forums 1 > Northwest
Old 06-28-2004, 06:34 PM   #1 (permalink)
kingj07's Avatar
Member Number: 2988
Default shooting for a 12. pac raceways wed 6/30
im going to be on zane's drag radials and might even go for some higher octane gas. we'll see if the 6 gallons i put in today (on blinking gas light) are gone by then. now that shouldnt be a problem, no... not the way i drive!
j.r.
kingj07 is offline   Reply With Quote
Old 06-28-2004, 09:25 PM   #2 (permalink)
ViperManiac's Avatar
Member Number: 7913
yo man i might just go haha!! then next week ill go and have money hopefully...paychecks go by fast!
ViperManiac is offline   Reply With Quote
Old 06-28-2004, 09:59 PM   #3 (permalink)
Senior Moderator
inzanesrt4's Avatar
Member Number: 1426
We can add two gallons of Xylene to the tank you have now and you'll have less then 1/4 tank race gas on race day. Plus be running on race gas next two days.
ATTN : Everything said on the forums is 80% truth at BEST
I am not your role model, I am not here for you to look up to, I am not here to mentor you.
I am here to moderate you, and occasional Pimp Slap you A$$ when you get out of line.
inzanesrt4 is offline   Reply With Quote
Old 06-29-2004, 04:46 AM   #4 (permalink)
Member Number: 13012
Good luck to you. I'll see ya there. BTW...I'm the guy in the white 92 Talon that you raced a few weeks ago. That was the best race of the night by far. I'd try to run, but the tranny is about ready to give up the ghost.
9D2AWD is offline   Reply With Quote
Old 06-29-2004, 12:29 PM   #5 (permalink)
kingj07's Avatar
Member Number: 2988
dude! that was a kick ass race! theres supposed to be another copy of the vid to be posted here (i posted my copy). i assume it might be somebody you know... other thread
btw, i already got my blinking gas light again, but just put 3.5 gallons in this time. while i was down there in auburn i picked up 5 gallons of 114 octane. i hope they work out!
j.r.
Old 06-29-2004, 01:58 PM   #6 (permalink)
Member Number: 3391
JR did u put in your stg 2 toys yet? if not then your not gonna gain anything from running race gas. its a common misconception. you should use the lowest octane possible without getting detonatoin. look at me im running nitrous and 19psi on pumpgas. no detontation and no knock. once i advance the timing though then i will run race gas when i squeeze because i also changed my nitrous jets to a 105 shot
Gone mustang hunting see ya in 11 seconds:P
'06 EVO 9 RS RED Sponsored for 2008 Bridgestone Motorsports
18X9.5" Enkei GTC-01 w/ 265/35-18 Bridgestone RE-01R
AddictMotorsport 3.5" Turboback
AddictMotorsport 1600cfm I/C
JR motorsports drop-in filter
ECUFlash
360+WHP stock turbo is the current goal
2002 HONDA RC51 (2005 graphite bodywork)
Jardine pipes, PCIIIR, Attack Rearsets, Michelin 2CTs!!!!
Dyno'd @ 131.4rwhp 74.8ft/lbs
In the works: 1997 Neon RACE car (2300lbs) 220+whp
in10se is offline   Reply With Quote
Old 07-01-2004, 12:53 AM   #7 (permalink)
kingj07's Avatar
Member Number: 2988
yeh. race gas = teh suck. i have nothing good to report i didnt even make it to my previous best time. i was able to trap at 106.3 and i had only one sub 2 sec 60' time. the only idea i have is to check for boost leaks and use regular gas.
9d2awd was helping me out with the tires & launching, but i wasnt able to nail it in the few runs i got after his help.
j.r.
Old 07-01-2004, 01:24 AM   #8 (permalink)
Senior Moderator
inzanesrt4's Avatar
Member Number: 1426
So you got tires on OK?
Do you you have a tire pump with gauge we can check for leaks.
Running race gas will allow you to increse the boost safely.
Old 07-01-2004, 01:28 AM   #9 (permalink)
kingj07's Avatar
Member Number: 2988
yeah, the wheels fine.
i kinda built the boost leak check tool, but could not find the correct size hose, so it hasnt been done quite yet. i think it will work, tho if i clamp it to the turbo inlet. ive got a compressor here for once the contraption is ready. another concern i had was over pressurising it. didnt want to fill up the system while my guage goes nutz without me even knowing it.
j.r.
Old 07-01-2004, 01:36 AM   #10 (permalink)
Senior Moderator
inzanesrt4's Avatar
Member Number: 1426
I can see your concerns with using a compresser. We always used a bike tire pump with gauge you pump it up and see if pressure holds. You can also watch your boost gauge. We always hooked straight to the turbo, just take off the ribbed rubber thing( No Pun intended).
Old 07-01-2004, 04:57 AM   #11 (permalink)
Drag radials can be tough to get right. I don't think those 205/40-17s are going to do you any good though. There's just not enough sidewall to help. If you can get some 225/45s, you'll notice much better performance out of the hole, but your gearing is going to be a little off because they will be about 6/10ths of an inch taller... 225/50-15s would be perfect. The effective gearing will be close to the same, but you'll be able to control the launches more and be more aggressive. There are plenty of aftermarket 15s that will fit over the brakes too. You will get to the 12s soon. I think the car has enough to do it. Just needs a little traction.
Sam Crawford
92 Talon TSi
12.36 @ 114 - Race gas and 25psi
13.28 @ 107 - Pump gas and 20psi
Old 07-01-2004, 06:45 AM   #12 (permalink)
Member Number: 13048
j.r. ~ why no call for this one? my car got hit, so when I get the rental we will have to go. oh yeah, we'll get you into the 12's easy when we put the other half of your motor in.
jb-pipes
325 hp, 560 lbs. of torque, 7,600 lbs. Fast enough to catch you and big enough to do some damage.
What? No Decals?
If you can't beat 'em, wait 'till they stop and run them over.
8urVtec is offline   Reply With Quote
Old 07-01-2004, 12:37 PM   #13 (permalink)
SeanGTS's Avatar
Member Number: 5514
I just built my vacuum checker yesterday, not sure how you guys are doing it but it works pretty well IMHO.
Just go to home depot in the PCV plumbing section, get a coupling that fits over your turbo, buy an end cap for the other end, go find an old bike tire or anything with a schiedner (sp?) valve, drill a hole in the cap, stick that through and epoxy if you feel you need it.
Used compressed air, much easier Have a friend hold the throttle down and watch the boost gauge, i wouldnt go over 20.
RC Alltrac TRD Gear Box DVD Player Plus Perfects Koni + Eibachs Garrett Turbo Lovefab Manifold
SeanGTS is offline   Reply With Quote
Old 07-01-2004, 02:50 PM   #14 (permalink)
SRToc Member
jaymzx's Avatar
Member Number: 278
Trader Rating: (12)
Local tire shop could hook you up with a new valve stem/core for a buck or two. When testing for leaks, I would just eliminate an old cracked valve stem/schrader valve as a culprit
James
READ AND LEARN:
Old 07-01-2004, 08:00 PM   #15 (permalink)
Member Number: 8346
hey 9D2AWD talk to airpopoff im sure you know who he is and tell him to post the video that homo hasnt done it and its been weeks..
life is good
v8killer04 is offline   Reply With Quote
