Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Regional Forums > Regional Forums 1 > Northwest
Old 05-22-2005, 08:49 PM   #1 (permalink)
2tirefire's Avatar
Member Number: 11405
Trader Rating: (10)
Exclamation PTPERFORMANCE Check Valve
I met up with John today (PTperformance) and put on the check valve system to prevent boost leaking from the PCV. The check valve is high quality and all I can say is wow. I gained an Extra 1 to 2 lbs in each gear. I can consistenly hold 14 to 15 lbs in 3rd and above. I definitely reccomend this mod for anyone out there that is looking for a gain in boost (aren't we all). He is starting to sell the kits that come with all the fixings to put it together, if you are interested PM him, and he can hook it up. Thanks again John. My car thanks you
2tirefire is offline   Reply With Quote
Old 05-22-2005, 08:55 PM   #2 (permalink)
kingj07's Avatar
Member Number: 2988
as well as me and my car
j.r.
kingj07 is offline   Reply With Quote
Old 05-22-2005, 10:27 PM   #3 (permalink)
NorwayGT's Avatar
Member Number: 15050
kinda noobish, but.......what is it? can you explain it for me
1.9 60ft 12.9@106 266hp 333.5tq
S1, mbc, agp wga, 3 inch dump TB, ngk plugs, msd wires, boomba MM's, dynoworks tranny mount, hochkis springs, tokico illuminas, hotchkis sway bars, DC front/rear strut tower bars, mopar STS, booger shifter bushings, MBmotoring 16x7's, 225/45/16 kdw's
NorwayGT is online now   Reply With Quote
Old 05-22-2005, 10:51 PM   #4 (permalink)
kingj07's Avatar
Member Number: 2988
the pcv comes off the top of the motor and is supposed to block air travel going in. this is because the other end of the line is connected to the intake manifold. the valve fails causing your intake air to be bled off. once the check valve is in place you lose no boost through the pcv.
the check valve is located at the manifold end of the hose.
j.r.
Old 05-23-2005, 04:18 AM   #5 (permalink)
ptperformance's Avatar
Member Number: 25514
Trader Rating: (554)
thanks guys for the posts. norwaygt, the valve was originaly made for reduction of pressure in the crank case due to the pcv system leaking boost into the valve cover thus buy reducing the leak into the crank case we have now seen an increase in boost. very cheap and effective mod. again thanks to jr and mark.
Old 05-23-2005, 08:39 AM   #6 (permalink)
NorwayGT's Avatar
sounds cool. does anyone have any pics?
Old 05-23-2005, 09:32 AM   #7 (permalink)
BACARDI_DWB's Avatar
Member Number: 20780
Trader Rating: (18)
its a great product... i have a boost controller so the increase doesn't really make any more boost for me but it feels more positive. and i know i am not loosing boost
SRT Sold
BACARDI_DWB is offline   Reply With Quote
Old 05-23-2005, 12:36 PM   #8 (permalink)
2tirefire's Avatar
Trader Rating: (10)
Norway, I would hit John up on PM and he maybe can snap a pic off, but as you know I am stock with stage 1 and I can hold this boost schedule which I have never seen...
1st - 11 lbs
2nd - 14 fades to 12 at redline
3rd - 15 fades to 14 at redline
4th - 15 fades to 14 at redline
5th - Haven't checked yet
Old 05-23-2005, 02:38 PM   #9 (permalink)
Member Number: 9833
1st - 11 lbs
How long did it take to install? Any Idea how it'll work on a stage 2?
Headhunter is offline   Reply With Quote
Old 05-23-2005, 02:43 PM   #10 (permalink)
bodizapha13's Avatar
Member Number: 10558
Trader Rating: (17)
There is a pretty good thread about the subject. Long read but it has several pictures in it and a how to. Very informative.
PCV valve leaks under boost so get Check Valves
bodizapha13 is offline   Reply With Quote
Old 05-23-2005, 02:50 PM   #11 (permalink)
Trader Rating: (18)
10-15 min to install (beer included in time lol) and yes it will work on any stage car..
Old 05-24-2005, 12:49 AM   #12 (permalink)
2tirefire's Avatar
Trader Rating: (10)
Only works on cool fast silver cars though!!!!
Old 05-24-2005, 01:58 AM   #13 (permalink)
Dark Syde SRT-4's Avatar
Member Number: 18242
Trader Rating: (79)
i need one by tomorrow lol is it possible?
Dark Syde SRT-4 is offline   Reply With Quote
Old 05-24-2005, 03:12 AM   #14 (permalink)
pm me, i have physical therapy at 10:30 and should be home around 12:00. i will pm you with my number and we can put something together.
Old 05-24-2005, 03:21 AM   #15 (permalink)
Works great with all stages. The reason for the valve originaly was to keep the pressure out of the valve cover/crankcase because the pcv valve leaks boost into that area. It has just been a benifit to get more boost and quicker spool of the turbo. Install time is 5 min. to 15 min. depending on with or with out cc.
