PTP customer "DAYS", this is for PTP customers only, thanks
There are lots of things with your car that people take for granted. Fluids, plugs and wires, and over all health of your car.
ADDRESS
PTP
18502 SE 263rd St
Covington, WA 98042
This is what I have in mind. Through out spring and early summer I want to get a bunch of one day events set up so people can get thier cars running in top shape.
What I am thinking:
Boost leak days
Fluid flush days
Injector cleaning day
Tune up day
Dyno day
BBQ day (every one day event wil have a BBQ as well)
We just had a boost leak day and those will be free ever time we sponsor one.
Fluid flush days will be trans, brake and power steering fluid, cost to you:
$85.00 (fluid costs have gone way up due to oil on the stock market going up)
DATE FOR THIS WILL BE mAY 18TH WE HAVE 8 SPOTS AVALIABLE ONLY!!!
START TIME WILL BE 11AM AND WE WILL BE FINISHED AT 7PM. THERE WILL BE FOOD TO EAT AND IF YOU WANT ME TO KILL SOMETHING ON THE BBQ FOR YOU I WILL.
PLEASE SING UP FOR THIS NOW
1. fr33fir3
2. Tommy the SRT
3. need4speed2345
4. inzanesrt4
5. valeriekay_2000
6. Skittle
7.
8.
We will use Mopar ATF+4 for the trans and power steering and a good DOT 4 brake fluid for the brake fluid. We will have Royal Purple on hand for the trans and power steering for those that want to upgrade. If you want to swap over to a silicone or DOT 5 brake fluid that will be something you have to schedule with us because the system needs to be flushed with mineral spirits. DOT 5 fluid and DOT 3/4 don't mix thats the reason for the flush. We will only be able to get 6 to 8 cars done for this event and expect to spend the whole day getting this done because there will be no order of importance for those that get there cars done first. Its around 45 minutes per car to get all the fluids flushed. We use pressure or vacuum systems to flush the brake and power steering systems. Using the correct tools means you get the most out of the flush.
Injector flush day, cost to you:
$59.00, $175.00 if you want a new fuel filter as well (parts prices have gone up. The filters cost me over $100 now)
DATE FOR THIS WILL BE MAY 25TH, 10 SPOTS ONLY AND WE WILL HAVE OTHER CLEANING OPTIONS AS WELL FOR AN ADDITIONAL COST
SIGN UP FOR THIS NOW START TIME WILL BE 11AM
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
We use an injector flushing tool that uses a pressurized can to feed the injectors with a cleaning solution that burns in the combustion chamber as well to clean out deposits. We then put a can in the tank for long term cleaning of your injectors and combustion chambers. Normal price for this is $199.00 at most shops and dealerships. This normally takes 20 minutes per car so we will only be able to get though so many cars in one day.
Tune up day, wires and plugs, cost to you:
$55.00 (plugs and wires, we have red, black and blue wires to choose from and NGK and Champion plugs)
DATE FOR THIS WILL BE JUNE 1ST 12 SPOTS AVALIABLE. ADD $5 FOR A BOOST LEAK, $3 PER CLAMP WE HAVE TO TIGHTEN AND $5 FOR EACH HOSE WE HAVE TO REPAIR
PLEASE SIGN UP FOR THIS NOW
1. Tommy the SRT
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
We will gap the plugs and check the coil out put with the lab scope before and after the tune up to verify the changes.
That should about do it guys. If Zane will sticky this that would be great, thanks.
How much less if I don't need tranny flush?.. Just did it last 6 mo ago and only got 3k miles since then. But I definitely want to come. So put me down.
