» Tire Upgrade Garage
Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Regional Forums 1 > Northwest
Old 05-09-2008, 11:53 PM   #16 (permalink)
ptperformance's Avatar
Member Number: 25514
Trader Rating: (529)
Quote: Originally Posted by inzanesrt4 View Post
The 18th should work for me. I will probably bring my own brake fluid because of the Willwoods. Call me before hand and tell me what food to bring.
I probably dont need the other service days but I'll probably show up just to BS.
Do we need tattoos or special gang signs to be PTP customers?
Nope but you will be checked to see if you "measure" up to swing with the big dogs.
Old 05-10-2008, 12:21 AM   #17 (permalink)
Member Number: 63819
just curious but do you do any work on evo's? i like your plug and wire setup, if you want to do a evo let me know the final dates and ill get with you.
also do you have any t-bolt clamps and silcone couplers, the couplers and hose clamps on my upper intercoolerpipe for my evo are trashed.
nightfighter29 is offline   Reply With Quote
Old 05-10-2008, 11:36 AM   #18 (permalink)
COY
COY's Avatar
Member Number: 35663
Trader Rating: (23)
Do any of the services come with a "used" towel
COY is offline   Reply With Quote
Old 05-10-2008, 11:49 AM   #19 (permalink)
Yes we can take care of you. I though the EVO's were all coil on plug set ups??? Let me know and I can get a set of plugs here for it if need be.
I have the t-bolt clamps and silicone here but i need to know what size of silicone. I have 2.5 in most sizes and 3 inch in a few.
Old 05-10-2008, 11:31 PM   #20 (permalink)
LiquidPT's Avatar
Member Number: 21983
Can we play "find my leaks"? I seem to be leaking at least PS fluid...
2003 Bright Silver GT, Stage 1, VAK5, PTeazer Retro roll pan, Keystone single-scoop Good Hood w/ Airraid intake, custom dual exhaust, 06 tail lights, custom gauge pod w/ boost and D-PIC, 17" Mille Miglia EV05 wheels, Eibach Pro Kit, Tokico shocks/struts, Suspension Techniques sway bars, 14.682 @ 94.71mph
LiquidPT is offline   Reply With Quote
Old 05-10-2008, 11:40 PM   #21 (permalink)
Nelson's Avatar
Member Number: 52787
You're lucky it's a small leak... I'm going through a quart a day right now until dealership opens. The trouble is finding the problem with all the fluid there!
Proud Owner Of The S.S. Neon
Stage 2 w/o, Maxxfab 3in o2 and 3in SEE no cat/no res, AGP Race BFMIC, AGP Hard Pipe set, HKS bov, plugs and wires, AEM CAI, BWoody MM, CC, Check Valve
Awaiting Install: SST V.3, External Gated Intimidator ex manifold, Safc Neo, 2 guage pillar, Scan Guage, 30/30 boost gauge, AEM wideband o2
Nelson is offline   Reply With Quote
Old 05-10-2008, 11:49 PM   #22 (permalink)
LiquidPT's Avatar
Well, I'm leaking PS... I was leaking oil and I thought I had fixed it, but now I sure. And I have an exhaust leak (again, thought I fixed it, but definitely haven't)
Old 05-12-2008, 07:40 PM   #23 (permalink)
Skittle's Avatar
Member Number: 51131
Count me in for the 18th, its time for a tranny fluid change, 45k It will be nice to put some faces with names on here. The srt forums are way more fun than any other one I have ever been a part of.
12 second Stock Turbo Stage 0 SRT-4
http://www.youtube.com/watch?v=NAu6hxCaQxU
12.40@110.44mph 4/11/08 Mission Raceway
Since then added:
BFMIC
Wideband
Prayer for warmer tracks.
Skittle is offline   Reply With Quote
Old 05-12-2008, 07:45 PM   #24 (permalink)
Skittle's Avatar
I have extra t bolt clamps that came with my front mount, if john doesnt have any extra by then and you are there on the 18th or the 1st I will have them with me.
Old 05-13-2008, 12:41 AM   #25 (permalink)
sweet, i need two 3 inchers and possibly two 3 1/4 inchers for my charge pipe depending if i want to put it on. def need new couplers since the ones that came with it are rubber for some reason.
Old 05-13-2008, 01:16 PM   #26 (permalink)
fr33fir3's Avatar
Member Number: 54378
Hey John, If we dont get many shows.. Think we can do a coolant flush?
www.Kingclamp.com
For All your map clamp needs.
fr33fir3 is offline   Reply With Quote
Old 05-13-2008, 05:00 PM   #27 (permalink)
Northwest Moderator
inzanesrt4's Avatar
Member Number: 1426
Do I have to add the names to the first post for you John?
ATTN : Everything said on the forums is 80% truth at BEST
I am not your role model, I am not here for you to look up to, I am not here to mentor you.
I am here to moderate you, and occasional Pimp Slap you A$$ when you get out of line.
inzanesrt4 is offline   Reply With Quote
Old 05-13-2008, 05:54 PM   #28 (permalink)
You have been added, punching Matt will work for the gang sign.
Quote: Originally Posted by valeriekay_2000 View Post
Sign me up for the 18th, I dont need the tranny flush, but could use a brake/power steering flush.
Added and we have lots of brake and power steering fluid on hand.
Quote: Originally Posted by fr33fir3 View Post
Hey Jon Can you put your address on the original post. I cant remember the street address. need to plan out driving time from Portland.
Done, thanks.
Old 05-13-2008, 05:55 PM   #29 (permalink)
Nope I am getting to it right now.
Old 05-13-2008, 05:56 PM   #30 (permalink)
If its quick and easy yes. If we have to clean and add dye for leak testing...no.
