Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Regional Forums > Regional Forums 1 > Northwest
Old 10-12-2007, 01:24 AM   #1 (permalink)
BackFromTheGrave's Avatar
Member Number: 53922
Default Problem?
Ok so I put the new mani and tb on today.. Now my idle is at 1100 rpms. When i'm driving and i push the clutch in the rpms dont go down like normal. They stay up untel I have fully stopped. I'm guessing this has to do with my TPS sensor right? Maybe I put it back on wrong.
Ohh yah...NO vacuum leaks. All lines are A ok.....
-AGP 50 trim kit @ 26psi, AGP Return line
-ACT 6 puck, AGP shift selector
-DW 650 injectors, Perrin fuel rail, Apexi SAFCII.
-Walbro 255, Ported & Polished Intake Manifold
-55mm TB & Spacer, 3" dp with cutout, MBC,
-Stage1 pcm, BFMIC, CAI, Greddy BOV
-MSD wires, Iredium Plugs,
-AEM wideband,Autometer Oil , Boost & EGT
-AGP motor mounts
BackFromTheGrave is offline   Reply With Quote
Old 10-12-2007, 01:34 AM   #2 (permalink)
SRT-4aKid's Brother's Avatar
Member Number: 14173
I guarantee you it's because the pcm hasn't gotten used to the new mani yet. When I put on my 55mm tb the pcm did the same thing for the first couple days as it learned the new characteristics of the air flow. Give it a couple days and I bet it's fine.
Stg. 2 w/o, AEMuego/map clamp & CAI, AGP WGA, ED Wuss IC, PTP 55mm TB & O2 housing, MaxxFab 3"dp w/resonator & Mopar Exhaust, ported intake & exhaust mani's, S1 springs, budget sways, DC strut bars, Prothane race inserts, Eagle F1 GS-D3's
Quote: Originally Posted by my grundle is hairy
i'll keep posting til my grundle goes bald
SRT-4aKid's Brother is offline   Reply With Quote
Old 10-12-2007, 01:44 AM   #3 (permalink)
Smart man!
PS...Im ordering a walbro 255 fuel pump in the next week or so. Along with the SAFC...I don't got a return line...Whats the deal with the FPR with the 255?...you still use the stock 1?
Old 10-12-2007, 02:04 AM   #4 (permalink)
The Hotness's Avatar
Member Number: 53381
I would just double check that brake booster line, cause that's what it sounds like.
You still interested in the super? I will be in Lynnwood Saturday!
The Hotness is offline   Reply With Quote
Old 10-12-2007, 02:04 AM   #5 (permalink)
Srt4Ronin's Avatar
Member Number: 25693
Trader Rating: (18)
Check the throttle body cable once more. I had that happen to me once. Took the cable off, put it back on, and it was back to normal. For whatever reason it was just binding on something and throttle was partially opened all the time. Couldn't hurt to check.
Srt4Ronin is offline   Reply With Quote
Old 10-12-2007, 11:10 PM   #6 (permalink)
Checked it..At idle it is shut to where it should be...
Don't think its the PCM now...Its doin it to bad to be the pcm.
Old 10-12-2007, 11:21 PM   #7 (permalink)
turbofrog's Avatar
Member Number: 35459
Trader Rating: (12)
????????????????????????????????????????? Try using english and assume we can't read you mind.
FYC
turbofrog is offline   Reply With Quote
Old 10-12-2007, 11:21 PM   #8 (permalink)
Senior Moderator
inzanesrt4's Avatar
Member Number: 1426
wiggle the TPS and you can ususally find out if thats the problem.
I have a really nice FPR laying around my storage some where let me find it. Its really bling bling. too much for under my hood. It was given to me as a gift you can have it if I find it. Its more your style Brandon it will match that Perrin Fuel Rail.
ATTN : Everything said on the forums is 80% truth at BEST
I am not your role model, I am not here for you to look up to, I am not here to mentor you.
I am here to moderate you, and occasional Pimp Slap you A$$ when you get out of line.
inzanesrt4 is offline   Reply With Quote
Old 10-12-2007, 11:23 PM   #9 (permalink)
turbofrog's Avatar
Trader Rating: (12)
If it is the TPS I have a few new ones here.
Old 10-12-2007, 11:54 PM   #10 (permalink)
Senior Moderator
inzanesrt4's Avatar
Member Number: 1426
Frogs house here I come maybe the third times the charm.
Actually I think I'm following Randy's idea and just taping the hell out of it so it cant move.
Old 10-12-2007, 11:56 PM   #11 (permalink)
srt4moster's Avatar
Member Number: 24528
how many miles you have on the intake manifold setup?
srt4moster is online now   Reply With Quote
Old 10-12-2007, 11:59 PM   #12 (permalink)
ToMuchBoost's Avatar
Member Number: 35620
Trader Rating: (69)
Do you need the TPS sensor or the rewire? I have an extra used sensor laying around somewere
FYC Racing
Build Thread Here
ToMuchBoost is offline   Reply With Quote
Old 10-13-2007, 12:59 AM   #13 (permalink)
ptperformance's Avatar
Member Number: 25514
Trader Rating: (554)
Zane I have a hand full of those sensors sitting here. They show up all the time on t-bodys that people sell to me for cores all the time.
Brandon have you done a boost leak check?
Old 10-14-2007, 01:25 AM   #14 (permalink)
Member Number: 48549
Ok here is just a small suggestion so take it with a grain of salt. I do not think your turbo is big enough to cause enough back pressure to slow down the engine. So what I propose we do is we take a turbo off one of my Semi's at work and slap it on your car and that should fix the high idle issue fine.
mcmullenusmc is offline   Reply With Quote
Old 10-14-2007, 01:42 AM   #15 (permalink)
moltenice's Avatar
Member Number: 6528
Trader Rating: (24)
He knows his shit^^^^
Best idea evAR.
TPS or TIP.
moltenice is offline   Reply With Quote
