ok so this morning i was driving to work and my car falls on its face, i figured it was low on gas since the light had been blinking for a few days. so i have my wife bring me some gas at work and start it it dies i start it again and it runs fine, i get in it to go to lunch and as im driving it starts in again, with the car driving it hessitates and has no power after about 1500 rpms, out of gear it revs fine. while i was driving it also threw code p 0300. so would running out of gas cause the car to have multi cylinder misfires? whats wrong with my car?
i already reset the comp and cleared the code but its still bogging down while i drive it
" If you looking for something just comfortable enough to get to the track and then beat the piss out of everyone there.......the SRT-4 is it" - Car and Driver Television
ok well i did a little more dinking and its running good now, not really sure what it was i did a few things and one of them must have worked. but if anyone has any ideas please fell free to share them
Yeah if you ran it out of gas it could have this code. Also you probably had some air in the fuel lines causing the bogg. How far/long have you drove it since you ran out of fuel and have you gone to the gas station and filled up? If you are running real low on fuel then each time you accelerate you will uncover the fuel pickup causing it to suck air.
i was told to "purge" at the fuel rail. using what i think is a fuel return connection, did that a couple of time and i could hear the car start running better right away
I used to do that all the time after fuel pump installs in Caravans. They would trap air in the lines and it would take a good minute of bleeding it into a shop bucket. No worries about it getting on the motor or into a rag, trust me the motor see much worse then a little fuel.
